Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My 2000 fat boy is back firing real bad when you give it the gas, really loud and blue flames. I pulled the plugs and cleaned them and its worse.I also replaced the gas with 91 octane.
  • 116 Answers
Check your coil connections it sounds like a coil misfire ignition module or its connector would be my next stop also if your bike still has the cam sensor behind the point cover not sure what year they changed that but if youll pull that cover and its not just an empty hole then your looking at the pickup coil or camsensor call it what you will but its a very likely culprit
Posted on Dec 30, 2009
My gas fire has just had new coals replaced nice. Then there are large flames forcing through the gaps of the coal making loud noises as if there is a draft or air combining from some we're trying to
Paul is correct, but also check the air ajustment for the burners. If you have real large yellow flame the shutter should be opened till you get a blue flame.
Sep 03, 2014 | Heating & Cooling
No power when give it gas.
believe carb adjustment bad & carb needs to be rejetted to exhaust, believe you need to add a higher flow gas valve & possibly new plugs & wires
Apr 21, 2014 | 2000 Harley Davidson FLSTF Fat boy
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
Will exhaust from 2003 harley fat boy fit a 1999 harley fat boy
I doubt it. The Fat Boy is a member of the Softail family. In 1999, the Softails were running Evolution engines. They didnt' go to the TC-88B engine until 2000 and that required a frame change. I don't think it will fit but you never really know until you try it.
Steve
Sep 07, 2010 | 2003 Harley Davidson FLSTFI Fat Boy
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My kolpin fourwheeler will idle, but stalls when i give it gas
hello, make sure your spark plug is getting a good blue flame, if not you may need cdi, i replaced one on my atv, would idle all day would not rev up, cdi boxes is the brain of your atv, motorcycles tells it what to do as far as firing, timing advance, hotter fire to plug etc..my atv is a 2000 350 warrior, their known to not have very reliable cdi,lots of problems with warrior cdis....
Feb 21, 2010 | 2004 Yamaha YZ 450 F
How to stop gas leak between tank and petcock 2000 fat boy
there is a few things you can do use a teflon washer or tape mke shure that you get the fuel proof kind though.
Aug 04, 2009 | 2000 Harley Davidson FLSTF Fat boy
Back firing
what do you mean stupid? 87 89 90whatever unless you got some serious mods you shouldn't really notice that much difference in the performance between redily available octanes in pump gas. more likely a coincedence. timing; rich fuel mix; jets in carbs among other things can cause back firing. run the tank off or drain into yer mower and put in summpin else if it gets right again blame it on the gas if not the GAS didn't break it somthin else just got screwy good luck bro
Apr 22, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
198 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
