Question about HP OfficeJet V40 All-In-One InkJet Printer
Will not print with my new compaq laptop
My old hp offficejet v40 will not print with my new compaq laptop. It says it's not connected
Hello i want to connect my iphone 5 hotspot to my old compaq nx9030 but its not seeing my iphone talkless of connecting could it be the driver
HP compaq old
what makes you think, this laptop sports WIFI direct connect?
wow!
what are you doing name reason, a job a task.?
here ask at HP ,
HP owns COMPAQ, COMPAQ is DEAD now.
but does have very limited support , like here.
why in the world use XP the VIRUS MAGNET. ?
https://h30434.www3.hp.com/
Jun 14, 2017 | Compaq Computers & Internet
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Jan 12, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
HP offficejet 4315V all in one will print but wont scan. The error comes back-no scan options, no computer connection.
Go thru your control panel to "Printers and other Hardware",open that and you'll see "scanners and cameras".Open it and your printer will be there,highlight it and in the left column will be "get pictures".Click it and you'll be able to scan.
Jan 07, 2010 | HP OfficeJet 4315V All-in-One Printer
How do i access the print cartidges on my hp officejet v40?
Below is a link to the Setup Guide. Click on it and see steps 12 and 13.
V40 Setup Guide
Dec 07, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Hp officejet v40
Manuals for the V40 are available for download here. The information you are looking for is in the setup poster, part 6.
The wall connection connects to the rightmost connection (looking from the rear). If you have a phone it would plug into the leftmost jack. It may be necessary to remove a plug from the leftmost jack if you use an external phone.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 03, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printer problem
Try changing the best working cable USB cable. and if same error occurs try on different PC, or laptop
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
DonĀ“t Print my HP Officejet v40
From what I can see Vista already has the drivers for this printer built in, so if you have installed the Windows XP drivers from CD you may need to remove them first and see how it goes with the standard Vista drivers.
Please note that some functions may not be available as this product is not completely Vista compatible.
More information available at HP HERE.
Jan 21, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
