My HTC Touch Pro checks email but remains connected to internet after it has completed download.
SOURCE: I just got an HTC
Hi,there's built in setting wizzard,did you tried it?
START-SETTINGS-CONNECTIONS.
Rate me if helped. Thanks.
SOURCE: instructions to replace the LCD in my HTC Touch Pro - T7272
If you need, I can email to you service manual, which I bought to replace my broken screen. Every step described very closely and picture of every step taken as well.
SOURCE: cant access the INTERNET thru wi-fi!!!
I solved this by configuring the phone settings to REMOTE-NDIS HOST on the tab "Configure network adaptors". Select this, press OK and add your network password (if any).
Rico.
SOURCE: HOW TO ACTIVATE INTERNET SETTINGS IN HTC TOUCH PRO
You have to be more specific...HTC Touch Pro is available for sprint and Verizon...and can be flashed for metro pcs and cricket pcs..
for metro pcs, go here:
http://www.howardforums.com/showthread.php?t=1559514
SOURCE: Touch Pro2 won't go past the htc load up screen
hye.. i am having problem with my touch pro 2.. the phone is stuck, when i try to turn it on, the screen just load till the htc screen, and then it keeps restarting.. what should i do then?
You can easily unlock HTC Touch Pro2. Just insert Invalid Sim card. it will ask you for unlock code. Enter unlock code. Your Locked Touch Pro will be Unlocked and able to accept any GSM Sim card.
You should buy an unlock code from a trusted HTC unlocking service.
Check the recommended link.
