Question about Panasonic NN-T990SA Microwave Oven
Panasonic NNC980 - stops working after 3 seconds
We have a NNC980W microwave convection oven. It is approx 5 years old but was VERY rarely used in the first 4.75 years. 3 months ago, we started using it regularly (at least 10 times a day) and today it stopped working. The unit has electric power getting to it, as the display works. The problem occurs when setting a time for the microwave and then hitting start. The unit attempts to start as the light inside turns on and the timer reduces by 3 seconds before the light inside turns off and the display goes back to the clock. We also noticed that previously when we would start the unit, it would hum as soon as the microwave generator would start working. Now, the unit does not have the hum sound and the only thing that happens is the timer starts counting down for 3 seconds and then "click off". To try to isolate the problem, i tried to run the convection oven - the same problem was encountered - it started the convection program for 3 seconds and then it turned off.
Do you have any ideas what could be the problem with it? Can this problem be repaired? Is it worth repairing the unit or should we consider buying a new microwave?
    Problem Solver:
  • 7 Answers
You have a bad inverter board.
Posted on Feb 16, 2009
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 04, 2009 | Microwave Ovens
I have a panasonic v681 convection microwave when the microwave turned on for whatever time it starts for approx 2 seconds then switches off for no apparent reason
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Nov 27, 2008 | Microwave Ovens
Operates for 3 seconds on microwave then stops
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 15, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Dead microwave
check mains fuse and check control circuit and magnetron. and diodes capacitor  high voltage related circuit. small part also gone microwaveoven doesnot works, first check oven and conform which part was spoiled, after that this is worth or not old ovens good compaare to new ones...
Oct 25, 2007 | Panasonic NN-T888S Convection/Microwave...
Panasonic NN-T990SA Microwave Oven Logo
1,029 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
