Question about Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit
14.4 MXT grinding under pressure
I have a 14.4 mxt cordless drill, recently started making a grinding noise and not drilling whenever i put pressure on the drill while in operation, initially this was only happening in 3rd gear but now all gears. the drill is around 2 years old and only used for home use. a mate has the same drill and uses it for trade and has just started having the same problem. any ideas?
  • 2,176 Answers
There is a collar inside the clutch assemble that probably has the top of the teeth worn off. Unless you find a service center that has saved some good ones you probably will have to replace the whole clutch assembly.
Posted on Oct 01, 2009
How to replace keyless chuck
go to either the tip section or refer to my profile and you will find detailed instructions on how to remove the chuck. Let me know if you have any problem finding them.
Sep 10, 2010 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Makita 8444d second and third gears sound noisy and do not engage
I had the same problem on my 8444, it was out of warranty (just over 2 years old) so I stripped it and found the plastic gear selector ring worn out. Was livid at this as these drills are marketed on the strength of the "all metal" MXT gearbox! Makita UK, to their credit, sent me a replacement gearbox free of charge when I pointed this out to them.
A year on and the replacement gearbox has now started doing the same in 3rd (high) gear. Doubt I can get another free 'box out of Makita (they would probably say I fitted it incorrectly) so am looking at buying just the drill body, which comes out at around £60 and will work with my existing batteries. Just not sure if I would trust the replacement not to fail, but a similarly powerful drill with 2 batteries would cost me wel over £200.
Jul 20, 2010 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Keyless chuck is stuck with bit inside I can't turn it counter clockwise to unlock I have a Makita 6349d drill
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Nov 10, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Makita 6349DWDE 18V Cordless Clutch
could be the clutch needs replaced, but I would check to make sure the high/low switch is fully engaged. Inside the clutch there is ring gear that could have the teeth rounded off I would go to Makitatools.com and type in your model number for a breakdown so you can see what you are getting into, they are not that hard if you are mechanically inclined and just watch how you do it.
Sep 23, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Mar 28, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit Logo
217 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
