I want to connect the start button to the motherboard and also the usb's; firewire and the audio basically I require a wiring diagram so that I can install a new motherboard.
  • ocommon May 11, 2010
    whats the brand of your motherboard? it depends on the brand.. =)
    Problem Solver:
  • 19 Answers
The best place to start will be the website for whomever manufactured the motherboard.
Posted on Sep 28, 2009
Hi, i want to no, what is 1394 on motherboard and if the usb cable in the front write 1394, i install it like a regular usb cable?????
It is Firewire port/ Interface. The IEEE 1394 interface is a serial bus interface standard for high-speed communications and real-time data transfer, frequently used by personal computers, as well as in digital audio, digital video applications etc. The interface is also known by the brand names of FireWire (Apple), i.LINK (Sony), and Lynx (Texas Instruments). This is not as widely used.It works just like USB but it is meant for connecting Firewire capable devices. If you have any firewire capable device (like video camera)and firewire cable, you can connect the device to your PC and use it for high speed data transfer.
Hope it helps! Good Luck!
CreativeTECH
Apr 18, 2011 | Foxconn 661MX Motherboard (FOX661MXMB)
Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Jan 22, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Location firewire input port
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Nov 01, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
Searching for a wiring diagram for my E machine....
Industry Standard Architecture exists here.
The pin arrangements for USB are standard, some usb headers are attached to the boards in the opposite direction but the pin arrangement is the same.
USB headers consist of 9 pins, arranged as 4 pins and one missing, and 5 pins like this:
x x x x o
x x x x x
these are marked as:
vcc1 usb 0- usb 0+ n/c
vcc2 usb 1- usb 2+ n/c
colours are:
red, white green black
Note: some motherboards have these connectors back to front but the connection sare as per the diagram
the audio header is arranged as follows:
X X X O X
X X X X X
top row = gnd, vcc5, mic2,n/c line
bottom row = mic1,mic r, line out,front spk r, lin out L
The cable colours may differ but the preformed plug will only fit in one place /direction
Oct 27, 2008 | E-Machines (308714) Motherboard
Connecting motherboard ?
Hi,,
ok lets see if i can help you out here
basically IDE 1+2 Is primary and 3+4 is secondary, it doesnt matter where you donnect your harddrive to it will still work ,, the standered is to use 1 and 2
as for the frount usb aint working is cause they are not connected or the wires are mixed up.. basically you can connect the wires to any usb section of the mainboard as long as you connect it propperly.
each wire is labeled and the bord is labelled as well. for example connect ground to ground, v++ to v++, +5 to +5 and -5 to *5 there is a diagram on the manual showing the connection ports location and pin id's it also labebled on the main board.
Jul 19, 2008 | Computers & Internet
Asus p5s-mx se motherboard
The unit goes in a spare 5 11/2" drive bay, same type as your DVD player/writer; it is held in place with screws provided.
The audio cable connects to the 'front panel audio pinout' on your motherboard or if it is a plug there should be a backside slot cover provided that has a hole in it. You pass the plug through this hole and plug it into your audio ports, the green hole.
The1394 cable is called Firewire and connects to the firewire pinout on your motherboard.
The USB cable connects to an unused USB pinout on your motherboard.
Do you need a map of your motherboard that shows where these are? They are labeled clearly. If you have never had your hands in a PC to connect things to your motherboard LET ME KNOW and I'll advise you on how to do this safely so you don't damage anything or yourself.
If you have any other questions I didn't cover JUST ASK ME by commenting below and I'll get back to you as soon as I can.
Regards,
Worldvet
Jun 02, 2008 | Televison & Video
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
