Question about Linksys Wireless-G WRTP54G Router
Hi, my router stoped work suddenly. LEDs Blinking.
Hi, my router stoped work suddenly. The power, wireless and phones LED is blinking. I couldn't connect with computer, because didn't get an IP number. Anyone knows what can I do? I reset the router and dind't work.
Thanks.
    Guru:
  • 773 Answers
  1. Click Start>run
  2. type cmd and hit enter.
  3. At the command prompt type ipconfig and hit enter.
  4. Look for your IP address. it will be something like 192.168.1.2
So what every your computer's IP address is, If you change the las number to 1, that is your routers IP address. So if your IP is 192.168.1.4 then change the 4 to a 1, 192.168.1.1 and put it into your browser and it will bring up the router login page.
If you don't know your login, if your router is linksys, put admin in the password box with nothing in the username box and hit OK.
Posted on Dec 09, 2009
I have a router Netgear fwp114pv2 .. power led and test led blinks and the router stuck at this blinking
Try RESETTING the router.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2011 | NetGear FWG114P Router (FWG114PAU)
My d-link router name no longer appears in my wireless networks list - I can not find it to connect to the internet wirelessly
Hi, this seems to be either an issue with your router's hardware or local computer wireless adapter hardware. In order to determine which one is it do the following:
1. Go and check the LEDs on your wireless router to see if there are any blinking or switched off as stated in the official manual documentation for DLink products (can be found here or here more specific).
LEDS are as follows (left to right - per official user manual/doc):
- Power LED = A solid light indicates a proper connection to the power supply. cdekatrr_0.png
- Internet LED = A solid light indicates a proper connection to the Internet port. This LED blinks during data transmission. cdekatrr_1.png
- WLAN LED = A solid light indicates that the wireless segment is ready. The LED blinks during wireless data transmission. cdekatrr_2.png
- Local Network LEDs = A solid light indicates a connection to an Ethernet-enabled computer on ports 1-4. This LED blinks during data transmission. cdekatrr_3.png
2. Check the laptop's or desktop wireless adapter if it is disabled or enabled and if is disabled enable it by going to your computer's Control Panel (either winxp or vista/win7) and go to network connections (in vista/win7 put the control panel in detailed view to see more options) and then right click on your wireless connection and click enable.
3. In a case that also the wireless adapter is enabled but you still cannot see any access points/wireless networks please go to your current wireless connection and right click go "Diagnose", this feature is mainly available in windows 7 or Vista. For windows XP, go to the command prompt by going to Start->Run->type in the box "cmd" without the quotes->Then type in the following set of commands.
ipconfig /release ---> This will refresh your wireless card IP settings/configuration to 0.
and after that command finishes, type in:
ipconfig /renew --> This will get new settings if the wireless card has problems finding an address from your router.
You can always reset your router (unplug from power supply, wait 2minutes then plug it back in)
or:
Reset the wireless adapter (right click from on the wireless adapter shown in the network connections, disable and then re-enable it) or computer.
Thanks please let me know if you need anything else.
Mar 20, 2011 | D-Link Wireless N 150 Home Router 4Port...
We are using WGR614 V8 Netgear Router it was working fine but one day after putting power switch on front panel of Router Power indicator LED and wireless LED are not glowing but Test LED, internet LED and...
no it never needs a hard ware repair... doing a hard reset for the router will help... press and hold the reset button on the router for 10 to secs using a paper clip or any safety pin.... reconfigure the router when reset is done completely...
Dec 13, 2010 | NetGear WGR614 Wireless Router
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Router WRT54G no Power led on
HAVE YOU PRESSED THE RESET BUTTON ON REAR OF ROUTER (LEFT SIDE).IF NOT TRY THAT OR FOR MORE INFO CONTACT TECH SUPPORT AThttp://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapperRICHARDM69
Jan 03, 2009 | Linksys Wireless-G WRT54G Router
No power led, wlan led blinking
well, what you could try is unplugging the power source from the cable modem, and the router. wait about 1 minute. then plug everything back in and wait.
i remember having this problem as well, but i think the problem with me was that my wireless computer was too far away from the wireless router, not saying that your too far or not, but that what i had, so i just pitched the wireless adapter, and created an ethernet connection. just sharing my experience.
Feb 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Belkin 5D3230-4 not working at all
Try and update your firmware on router,and see if that helps, you can go to belkin website to do that, look up your router and download firmware, call belkin they will help u install it
Feb 05, 2008 | Belkin (F5D7230-4) Router (587009)
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRTP54G Router Logo
105 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
