Question about Dell A920 InkJet Printer
Black Ink will not print. Was printing one minute
Black Ink will not print. Was printing one minute then nothing the next. I have been useing the same ink cartridge for a few rfills. Color seems to work fine other than it is almost out of ink.
  • 13 Answers
SOURCE: Printer will not print with color cartridge in
go to dell AIO center
click maintain/troubleshoot on the top
under trouble aio problems - click ink levels
click maintenace tabs
and then clean print cartridges and align print cartridges. then try printing a test page.
if this does not work, remove the cartridges and install them again.
let me know how it goes
Posted on Dec 28, 2007
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
  • 40 Answers
SOURCE: want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Posted on Jan 25, 2009
1alexh
  • 484 Answers
SOURCE: my Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
Posted on May 22, 2009
  • 157 Answers
SOURCE: Printer does not print using black ink
Check your settings i=under the Services Toolbox. Also go into printer preferences and see if you can force it to print in black only.
Posted on Apr 26, 2010
I know I am not low on ink (black) but I can't print anything in gray scale-comes out cyan. Changed black ink to a brand-new tank and still nothing. Took out CMY tank and still nothing. Worked the...
When you go to print, next to the printer selected hit "Properties". This may vary for various printers but under my Color options there is an option to print in grayscale. Look for this option and select it. Also, under print in grayscale it has an option to print in black ink only. Look for these options under your printer's settings.
Jun 04, 2011 | Canon PIXMA MP130 All-In-One InkJet...
How do i mix the colours on my stylus sx115 as i have run out of black but have the other 3 colours remaining?
Conserving Black Ink When the Cartridge Is Low (For Windows Only) The window below appears when black ink runs low and there is more color ink than black ink. It appears only when plain papers is selected as the paper type, and Text is selected as the Quality Option.
The window gives you the option to either continue using black ink normally or conserve black ink by using a mixture of color inks to create black. Click the Yes button to use a mixture of color inks to create black. You will see the same window the next time you print a similar job. Click the No button to continue using the remaining black ink for the job you are printing. You will see the same window the next time you print a similar job, and again have the option to conserve black ink. Click Disable this feature to continue using the remaining black ink.
Oct 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Does not print black colour
Is it nothing black? Try this. Move cartridge to parking position. Whith only black ink tank instlaled, **** the ink from the outlet pipe of head cleaning mechanic. If there is ink, the black head is not clog. Then try to print. If it's still no black ink printing, may be the electricity of black head is lost contact. so, the micro pump can't work good.
May 27, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus C88 won't print black ink
You have tried almost all the steps. You have to consult Epson Service Support. Don't try more the head can damage.
Mar 06, 2009 | Epson Stylus C88 InkJet Photo Printer
For a while the black ink wasn't printing and only the color... and because I was not able to print using black ink, I stopped using printer, and now color doesn't even work It just prints blank pages....
The print head is clogged. I had the same problem with only the black ink. I tried to soak it over night and let it sit on a paper towel soaked with windex. this didnt work so I figured it was time to replace the printer as the print head was probably just as expensive as to buy a new one. So with nothing to loose I got out my trusty can of WD40 removed the print head, removed the ink cartridges from the heads, sprayed the bottom and filled the top where the ink cartidge sits and within 15 minutes the WD40 began to flow on the paper towel. After a while I cleaned out the excess WD40 and replaced the cartridges and head to the printer and it worked perfectly. Good Luck. You have nothing to loose.
Joe B
Jan 27, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Ink replacement has not helped print
Sounds like a damaged or dirty flex cable to the print heads. If those tiny contacts go bad, nothing will print properly. Check the cartridge and socket area for any dirt or dis-coloration. The connections can be cleaned with contact cleaner (from radio shack), and then dried with isopropl alcohol (use the purest you can find).
Jan 03, 2008 | Lexmark X1240 All-In-One InkJet Printer
PRINT command
uninstall ink with printer on and turn off then back on when printer says install ink do so if that doesnt work clean contacts with rubbing alcohl on ink cartriges.
Dec 08, 2007 | Dell 922 All-In-One InkJet Printer
Black and yellow ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Dell A920 InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
