Question about Craftsman 25cc Gas Line Trimmer
My Poulan Pro 31cc string trimmer wont start, spark plug isnt getting any fire
3 Suggested Answers
SOURCE: no spark,craftsman string trimmer
  1. Remove the flywheel cover and pull the ground wire off of the off of the coil...
  2. Check for spark...
  • If you now have spark you have a "short to ground" some where in the in the wiring
  • If you still don't have any spark you'll need to replace the coil
Posted on May 21, 2009
  • 97 Answers
SOURCE: have 31cc poulanprolink gas string
.025
Posted on Sep 02, 2011
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
The trimmer was running fine when I ran out of string. I add new string and now I can NOT get the trimmer to start! I tried unscrewing the spark plug, making contact to the metal of the engine and...
Adding a new string has nothing to do with your spark. If your checking for spark make sure the spark plug is grounded to the engine either use a screwdriver to help you ground it. Lay the plug on the screwdriver shank then pull the cord. If still no spark remove a wire of the ground switch then try again. If you get spark then the switch is the issue if still no spark then you may have to check the leg gap of the coil to the flywheel. Adjust to around 11 thou if you can. If still no spark then i'd go on record to say you have a faulty coil.
Oct 20, 2017 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Won't start, won't fire after starting fluid is used, checked spark and its blue and very small. Has new plug. Suspect bad magneto, can it be tested? Thanks Don't know model, label on handle says Poulan...
First off you should never use starting fluid on a 2 cycle engine. Serious damage to the piston and combustion chamber could result. Try changing the spark plug and if it's neccessary to prime to start use a squirt bottle with the same fuel/oil mixture as required to run your machine. Try squirting a small amount into the combustion chamber through the spark plug hole. Squirt,replace spark plug,and start. Starting fluid also washes the cylinder of an oil and it could cause a siezure of the piston.
Sep 22, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Renewing the cutting line
This product is driving me nuts - if someone can't help then its going into the bin
Aug 28, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Craftsman 25cc Gas Line Trimmer Logo
1,312 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
