Question about Thermador Professional Series PO301 Stainless Steel Single Oven
My thermador professional stove is not working.
The gas for the burners turn on, but will not light. the electric griddle will not turn on. the lights that indicate whether a burner or the griddle is turned on, will not turn on.
  • 142 Answers
Sometimes there is an internal fuse...
Posted on Sep 28, 2009
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
Gas oven heats up to proper temperature and then quits heating.
It sounds like you may have a Whirlpool gas range. If so it is more that likely the burner assembly itself. The electrode attached to the burner gets to where it will light during the preheat but then once it starts to cycle the spark module tries three times to light the burner and then shuts down. the burner assembly comes as one unit with the electrode attached.
Nov 28, 2013 | Ovens
Thermador PRG364EDH/08 Oven will not ignite.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
Nov 09, 2013 | Thermador SC272T Electric Double Oven
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Oven will sometime take an hour to get to temp after being turned on. any thoughts?
If your oven is older or you live near the water check if there is a build up of fine rust over the burners. A fine wire brush lightly run over the top of the burners may be your solution. Before you attempt this disconnect electrical power and turn off the gas supply. If you are mechanical remove the front lower cover by opening the doors, removing the two screws located in the top of the lower cover next to the door hinges. The cover will remove to the front. Next remove the screws holding the shield in fromt of the burners. A long handled fine wire brush will allow you to brush the top of the burners. If there is a film of fine rust it will not be apparent when looking. After careful reinstallation of the burner shield and ensuring there is a safe area away from the exposed electrical connections for you. Reconnect electrical power and gas to the oven temporarily. This will alow the unit to be operated enableing you to look past the pilot flame to see if the burner flames are even across the burners. Disconnect electric and gas supply from the unit prior toiInstalling lower cover. After complete reassembly reconnect power and gas and enjoy.
Aug 08, 2011 | Blodgett DFG-100 Gas Single Oven
Gas stove with electric starters for the burners. One keep clicking after it lights. How do you stop the clicking?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 02, 2011 | Thermador Professional Series PO301...
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Jul 13, 2010 | GE JGRP17 Gas Single Oven
Thermador Professional Series PO301 Stainless Steel Single Oven Logo
402 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
