Question about Dishwashers
After a wash, water remains at the bottom of the washer
    Scholar:
  • 61 Answers
Water pump blocked
drain system blocked
If you have a washer with filter system check the filter it may be filled with dirt or even a coin as it usually happebs
if problem persists than the motor may be weak and not being able to spin properly
also did you check the waste pipe
if the motor is weak try to do this without clothes and if it empties than theat is the carbon that ere worn on the motor
Posted on Sep 27, 2009
The dishwasher doesn't finish the 30 min program. The display shows 1 minute remaining but the washer doesn't stop.
It sounds like the d/w has a heating issues. Possible internal failure of the heating relay.
Jun 20, 2016 | Dishwashers
Whybdoes water remain in machine at end of wash?
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
May 21, 2014 | Maytag Neptune Washer
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
After the wash cycle runs there is water in the bottom???
At the beginning of the wash, some water remains down round the outlet.
If the outlet pipe is connected to a deviation of the sink siphon, the pipe should go up over the sinks bottom, in order to avoid back flow from the sink.
Jun 18, 2010 | RTO Appliance Switch For Dishwasher,...
Upper tray dishes are not cleaned(washed) the bottom are OK, why?
replace the washer water from bottom of the unit up to the top arm water feed assy,they get worn and water leaks by the hub arm that pressurizes the upper wash arm,this is also true on the center arm if the washer has one
Mar 09, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Sometimes the next morning after I have washed a load of clothes that evening, even though at night there is no water in the bottom of the machine, the next morning there is a small puddle in the bottom. ...
i think the drainage of your washing machine, is not functioning well,or it has a leak, that's why some water remain in the bottom of your machine..
check this one..
http://www.washingmachineadvisor.com/
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer not cleaning clothes
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Apr 05, 2009 | Kenmore HE2 Plus Front Load Washer
Water remain in the machine
the washer has a fluid filled ring around the drum to balance it as it spins, assuming do not actually see or feel water you may be hearing that liquid.
Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain.
Sounds like the pump is clogged or stripped out. It's mounted on the front of the motor in the middle of the bottom. There's only 2 clips and hoses that hold it on. These are known for stripping out in the middle. They are just plastic, but fairly easy to fix.
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
