Question about Canon iP4500 Photo Printer
My paper is not feeding from the back tray correctly. it's been working fine and then recently it just started feeding the paper crooked which causes the printer to jam.
jerryg50
  • 1667 Answers
SOURCE: Printer paper feed for Canon iP4200
There are probably problems with the rollers or the gear sequence that drives them. This type of repair may be more costly than what the printer is worth!
Jerry G.
Posted on Apr 19, 2008
mohammed387
  • 1952 Answers
SOURCE: Paper Jam on Rear
clean this roller
Posted on Jan 22, 2009
jonb3838
  • 237 Answers
SOURCE: My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
Posted on Feb 11, 2009
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
Paper feed crooked or all at once
? More than likely, something is jamming the paper feed tray... Take a look and clean it out. It is also not entirely uncommon for the printer to have a problem with gap space between the "feed" roller and the actual mechanism that prints. If it has never worked properly, then your best bet would be to bring it back... I have run into similar problems and the new printer worked fine in most cases... Also check if you can adjust a slider to fit the page tighter...
Oct 05, 2009 | Dell 922 All-In-One InkJet Printer
"paper-feed error"
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Jun 24, 2009 | Canon Selphy CP510 Thermal Photo Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Mar 13, 2009 | HP Officejet 6200 All-In-One InkJet...
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Laser jet 4m
There is likely a problem with your fixing unit (also called a Fuser).
This is a device at the exit of the printer that squeezes the paper between a pressure roller and a heat roller. The heat is what "fixes" the toner onto the paper.
Either your paper is being fed crooked, or there is a problem in the fixing unit itself.
Remove your drum/toner cartridge. Look into the empty chamber of the printer and see if you can see any objects or bits of paper. Clean it out as best you can.
If your toner and drum are separate cartridges, separate them and make sure they don't have any bits of paper stuck between them. If they are both contained in one cartridge, then skip that last step.
Remove your paper tray and make sure the tabs are set correctly. There should be a tab at the back to snug tha paper length wise, and one at the side to snug the width. Setting these correctly will help prevent crooked feeding.
If you can see your paper pickup roller just over top of where the tray fits, make sure it is clean and not too badly worn.
Try printing something but turn the printer off about 1/2 way through the print cycle. Open the door and remove the drum. The sheet of paper should be stuck inside the drum. Examine it and see if it was feeding crooked. After examining it, remove it carefully and throw it in the trash. Don't touch the type as it is not fixed and will dirty your hands or clothes.
If the paper in the drum was straight, then there is a problem with your fixing unit. If the paper was crooked, then there is a pickup/feed problem.
Feb 14, 2008 | HP LaserJet 4 plus Printer
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Canon iP4500 Photo Printer Logo
27 people viewed this question
old marine
old marine
