Question about HP Pavilion DV9500Z 17" Entertainment Notebook PC (AMD Turion Processor TL-58 at 1.9GHz, 3 GB RAM, 3
Hp dv9500 has vertical coloured lines on screen. windows starts up ok as i can hear the program sounds, but, no display
  • 788 Answers
The 9500 series unit, should still be within warranty.
HP offeers an additonal year for video problems.
That means if you purchased the 1 1/2 years ago, it is still in warranty.
Contact HP customer care and get it back. ASAP.
Hope this has helped.
Posted on Sep 28, 2009
LCD Screen problem - Whiteish with vertical lines.
It sounds like the inverter has failed. A small circuit board which lives under the lcd screen. While they are cheapish to buy, replacing them is risky as you have to dissasemble to screen itself. If, like you say, an external display works that rules out most other possibilties. The only other thing could be the screen itself. Bu it would only behave like that if it get smashed.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Nov 24, 2009 | HP GF939ATABA Notebook
White screen with vertical lines, can't do anything
Can you bootup in Safe Mode?
Press F8 when you bootup.
Then select LAST KNOWN GOOD CONFIGURATION. then check the Device Manager to see if the Video driver is OK and enabled. If OK then shut down and bootup again to see if it boots up normally.
If this doesn't work select SAFE MODE instead of Last Known ......
When Windows starts then select a Restore Point prior to the installation of the driver update and when it boots up again with luck it will be OK. The graphic card update maybe causing the problem.
Sep 22, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
No normal boot up, screen stays greyish white with lines.
if its booting up and yopu are not able to see the line then its most probably the display problem you better contact service centre bfore trying anything or use a external display to check its running
Aug 03, 2009 | HP Pavilion dv6000z Notebook
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
Display problem on Compaq Presario C310ea
problem in virus and second ram any one is problem in your laptop ..........ok fist cline your computer throught the antivrus program and not solve change the ram
Mar 31, 2009 | HP 435768-001 - Compaq Presario C300...
HP creen display Multiples vertical windows
http://www.nerdmodo.com/2009/04/repairing-the-display-problem-in-hp-dv2000dv6000 -series/
Mar 29, 2009 | HP Pavilion dv2000t Notebook
Vertical lines o my desktop
Sounds like your video inverter is bad or possibly the screen is going bad
Jul 21, 2008 | Toshiba Satellite M65 Notebook
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
HP Pavilion DV9500Z 17" Entertainment Notebook PC (AMD Turion Processor TL-58 at 1.9GHz, 3 GB RAM, 3 Logo
195 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
