Question about Garden
How would I replace the bar hold down stud bolt in my Stihl MS 310 chain saw? Thanks.
  • 148 Answers
At our dealership we replace the Bar studs with Heli-Coil and locktite for $20.
NOTE: Remove the old stud by double-nutting and screwing out of the case and marking the end that came out. Take it with you to NAPA and get the correct Heli-Coil size and a small tube of BLUE Loctite. (Might be cheaper to let the Stihl dealer do it)
Hope this helps!
Posted on Sep 28, 2009
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
I need the bolt that holds chain brake handle on at bottom.
Try IS Engineers - you can find them on google. They are very helpful and will, if essential, send a parts diagram with part numbers so you can choose the part you need then order it online.
Sep 04, 2015 | Stihl MS 260 16IN Gas Chain Saw
I have a Stihl MS 290, runs great, but the chain keeps tightening it's self on it's own
That's an unusual problem, usually the opposite happens. After making sure the chain brake is off, loosen the two nuts that hold the bar. Be sure to hold the bar up when adjusting the tensioner screw and adjust until the chain is just snug, but not too tight. While still holding the bar up, tighten the two nuts firmly. Check to see that the chain can move freely by hand. Then start the saw and run the chain at speed with something in front of the nose to check for adequate lubrication. You should note a slight fine spray of oil on the object in front of the nose of the bar. Inadequate lubrication, a chain that is binding on the bar, or an overly tight chain can cause the bar to heat up and expand, further tightening the chain. A properly adjusted Stihl saw will use almost all of the chain oil in the reservoir for every tank of gas. Too much oil is better than too little. The oil feed may have to be adjusted for operating in temperature extremes. If operating in very hot conditions, be sure that the saw has not run out of chain oil. The oil feeds faster when hot.
Sep 19, 2014 | Stihl MS 290 Chain Saw include 20" 50cm...
I can't tighten the chain on my stihl ms 251 chain saw
Pull the side cover and check for a broken or misaligned chain tensioner. I assume that you have loosened the bar nut on the side cover before attempting to adjust the chain tension. The methiod varies depending on whether your model has the side chain tensioner or the quick chain tensioner.
Dec 08, 2013 | Stihl 029 039 Ms 290 310 390 Chain...
Looking for the studs that holds the bar in place. There is 2 of them that screws into the MS 310 Stihl chainsaw
You have to go through a Stihl dealer or some one that sells that saw. there are some places i have gotten parts on line but its much quicker if you go to the sellers of Stihl saws
Jan 08, 2011 | Stihl Garden
Stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Dec 20, 2008 | Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
524 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
