Question about Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728
How do I unmount a schlage keyed deadbolt? There do not appear to be mounting screws on either side of the deadbolt housing.
  • 672 Answers
There should be two hole plugs on the face of the interior deadbolt housing, above the key slot. They must be pryed out to access the screws. Unless it is installed inside out, then the the plugs will be outside. Yes I have seen this before or I wouldn't have mentioned it.
Posted on Sep 27, 2009
Our schlage lock with thumbturn on inside and keyed on outside. inside lock position AND outside keyhole are sideways. is this normal??
I've never seen a lock like that was intended to be that way, but have made that mistake when the shaft that goes through the bolt portion of the deadbolt is square and is 90 degrees off in the square hole it goes through. If so remove two screws on the inside and take out assembly with the key hole, position key hole bottom, then put key side assembly with shaft through bolt portion of lock. Test the key to see if it locks and unlocks, maybe you need to position shaft 90 degrees to left or right to work, then put cover on inside house and the two screws.
May 19, 2016 | Schlage Locks & Locksmithing
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
I have a Schlage that was in when I bought the house. It is a double key deadbolt lock. Recently my key just started spinning around on the inside lock. The outside one still is functioning. I took a...
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Jul 26, 2011 | Schlage Locks & Locksmithing
I have a schlage deadbolt, keyed on both inside & outside but neither have any screws to remove. How do I remove the deadbolt?
There should be caps over two screws above and to both sides on the interior key cylinder. Carefully use a pointed tool to pry them out. This will expose the phillips head screws that hold the two halves of the lock together.
Sep 24, 2010 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
How do remove a schlage deadbolt that is doubled
You didn't indicate what mode. The little pins you refer to should be little caps snapped into the end of the screws. A very small screwdriver or a pocket knife should be able to remove them. Then you should have a screw head to work with. I can't remember, but it might be a square bit not a phillips head. See web site and look at installation instructions.
http://consumer.schlage.com/products/Productdetail.asp?StyleID=34
Jul 09, 2010 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have a Schlage double cylinder deadbolt on security door. If I try to lock/unlock from the inside, it works fine. From the outside, the key turns and turns but the bolt doesn't move. I am trying to...
there are 2 buttons on 1 on either side of inside key slot.. those must be removed... more than likely you will destroy them when removing..under you will find square drive screws or phillips..https://www.schlage.com/en/home/products/B62FFF.html
Oct 15, 2017 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Were were lock in my house, wouldn't work from the inside, or with the key, it would not turn on the way over. Now it is sitting on my kitchen table, how do I put it back together
spray with graphite first to clean put plunger back in side of door first then put lock side that has long rod sticking tru line up screw holes with holes in plunger then line up other side of lock and then put in screws tighten screws snug not over tight
Aug 22, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
New schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Jun 24, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Feb 08, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
979 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Jim Thurston
Mike
Tom Weglarz
Tom Weglarz
Level 1 Expert
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
