Dell printer problem reason AIO Cartridge Error,
Dell printer problem reason Cartridge Error 50C, followed instructions but it doesn't fix it
tom19511
  • 1601 Answers
SOURCE: Error message 50c on printer
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
note.gif NOTE: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Check and make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press the Select button.
This was from Dell's website
Posted on Nov 13, 2007
  • 298 Answers
SOURCE: cartridge error 50C on Dell printer A940
Were you aware of this Dell Printer A940 Cartridge scam!
Details
If this is not the problem then I would suggest
uninstalling & reinstalling the drivers from the
cd
Posted on Dec 29, 2007
Teckies
  • 226 Answers
SOURCE: 6150 Lexmark
is printer Cartridge new? if now try to purchase new cartridge. If it doesnt work your print cartrige is the problem.
Posted on Jan 17, 2008
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
The cartridge has a short in it and needs to be exchanged for a non-defective one.
Posted on Feb 02, 2008
SOURCE: dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Posted on Jul 08, 2009
Cartridge error 50c
Here's an article in the Lexmark website on "Cartridge Error 50C" and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. Just click on this link: http://bit.ly/cBu4mW. Follow the instructions carefully. Hope this helps.
Jul 05, 2010 | Lexmark X6150 All-In-One InkJet Printer
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Error 50c Using real Dell carts Tried reinstalling drivers still
Hi there Error 50c
Here we go try this out.
color cartridge.
Mar 26, 2009 | Dell A940 All-In-One InkJet Printer
Cartridge Error 50 C in manual A 960 No l
One solution is to replace cartridge snap-down levers  (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). This seemed to have work for several people with the same issue.
Nov 25, 2008 | Dell A960 All-In-One InkJet Printer
Cartridge error 50c
Have you tried the Lexmark Knowledgebase?
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:133:0:0&framed=&docid=ENUS8448&relevance=1
It addresses this specific issue. It sounds like a shorted cartridge. However, sometimes this just means that the contacts in the cartridge carrier need to be cleaned. You can do this by removing both cartridges and cleaning the electrical contacts on the cartridges as well as the ones they touch in the cartridge carrier on the printer. You can do this with a slightly damp soft cloth. You can also use a bit of rubbing alcohol as well.
I would try cleaning the electrical contacts as I described above before I'd do anything like getting new cartridges. If the problem persists after that and after following the instructions in the link I posted above, then it might be time to get new cartridges.
Aug 31, 2008 | Dell A940 All-In-One InkJet Printer
Cartridge error 50C on Dell printer A940
Can you pull out the catridges and make sure you have taken the plastic off the gold strips properly. That can cause errors as there will be no connection to the printer. I hope it's a simple solution and this helps you
Dec 29, 2007 | Dell A940 All-In-One InkJet Printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
77 people viewed this question
k24674
jasbo
jasbo
