Dishwashers
Problem for Bosch Dishwashers
Generic problem for all Bosch Dishwashers
Bosch she44c wash cycle time keeps ext...
By danankt71 on Sep 27, 2009
Bosch she44c wash cycle time keeps extending. Once averaged about 130 minutes, now starts at about 150 minutes indicated. Seems to hang up at 1 or 2 minutes before cycle end, then keep running for as much as 4 hours. Water is hot, filters are clean.
Solution #1
posted on Oct 10, 2009
Not Rated)
Springly
Rank: Apprentice
Rating: 0%, 0 votes
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
Was this helpful?
Yes
No
Solution #2
posted on Sep 29, 2009
Not Rated)
Krazytech
Rank: Guru
Rating: 90%, 660 votes
Hi, The dishwasher must get to 70c to advance thru the heating cycle.. check to see if the heater is coming on( lots of steam coming out when you open the door )..not getting hot then you could have a heater problem. if you are getting hot then you have a Thermo ... the thermo holds the the dishwasher until the temp reaches 70c before it will let it go into the next cycle...the thermo is under the dishwasher at the right side, white with two wires .. it screws into the tub...hope it helps it not let me know and I can help you more.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
Start button doesn't work. How do I fix it?
Answer
How can you run the pump (manually) on a F-P? I there is a way to go into the proramming.
Answer
what is the open compartment on the left side for, it has been leaking water
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repairmen
in Katy, TX
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
