Question about Motorola Mobility MOTONAV TN20 GPS Receiver
Sends me in the wrong direction and wrong places seems to need to be re calibrated or somthing
It takes some digging here to get to the download section but this page will give you the instructions, the link will be down in the text. http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/MOTONAV%20TN20/US-EN/_Documents/Static%20Files/MOTONAV%20Web%20Download%20Install%20Instructions%20v8.pdf This next link has the download link on the right of the screen http://www.motorola.com/support/v/index.jsp?vgnextoid=8d756d755961e110VgnVCM1000008806b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
It took me an hour to find this. Good Luck
Posted on Sep 30, 2009
Please show me how to calibrat Fargo dct4500 flipper sensor.
There is not a separate calibration routine specific to the flipper table or module. You can download the Fargo Workbench Utility directly from the manufacturer's website, and install it on your PC. It includes a printer information section that can calibrate sensors, film, etc., and also can send direct commands to the flipper to level itself ("home the flipper table"), as well as step it in either direction.
If you have an issue that is not addressed by these built-in calibrations and other tests, then your unit may need service from an authorized repair facility, like Safe-Card ID Services.
Feb 20, 2015 | Fargo Office Equipment & Supplies
HID Fargo dct4500 flipper problem
Zebra GK420T Red light keep flashing
Seems its loosing calibration, try to reset to factory defult setting and it will calibrate with the labels that have at the moment. Please check settings at windows drivers (should be set up at Thermal transfere if using ribbon otherwise Direct Thermal if not using ribbon.
That issue can happen aswell if when sending a job to the printer with wrong settings, it will overrwrithe the previose settings of the printer.
you can untick the setting " use printer settings" at drivers as well.
if you need diferent driver go to www.seagulldrivers.com - this driver let you to resett printer to factury defaults. Hope it helps.Paulo.
Apr 03, 2014 | Zebra GK420t thermal transfer and thermal...
Drive way gates wont close seems like they are not squared or dropped. i jacked them up to see and they were still catching in the middle.
check the supports check they are straight also look for chipped paint. it may have become out of line. and need putting back into place and bolted down. also check the pivot on the gates if you can jack the gates up then there is somthing wrong on the gate hinges.
Aug 31, 2013 | GTO Drive Way Gate Mighty Mule Solar Panel...
Compass
I'm not 100% sure (I'm a new Nexus 7 owner), but I have see some solutions out there. The consensus seems to be that the accelerometer or the magnetometer isn't properly calibrated.
There are apps out there which claim to calibrate your device sensors, but sometimes these apps need to remain open. Compass is often recommended.
The best (and most odd) solution I've heard is to have the app open and wave the nexus 7 around in a figure 8 pattern. Apparently this does some "voodoo magic" and the device seems to calibrate itself.
Lastly, I have also read that android compasses never seem to point to true north in apps like Google Sky, but is more apparent in larger devices.
If that doesn't help I would suggest contacting Google Support to see if there is a better solution or if they can swap it out.
Phone Number: 1-855-83-NEXUS (63987)
Best of Luck!
Dec 19, 2012 | Google Nexus 7
Difinitive prosub 600 keeps turning its self off??? I have connected the sub every which way, low level RCA to sub out, using the prosub 600 as a bus for the front monitors, even both together. I have...
"Somthing seems to be wrong with the automatic on/off???" That's my guess too. Your sub requires a certain signal level to turn on, probably because of a sub-sonic filter. I just changed to another sub that did not have that "feature". Problem solved.
Jul 19, 2017 | Definitive SubAmp 600 Amplifier
I get a notation "that direct x cannot be found"
or you need a newer version of direct x or the game is broken or direct x is broken.
i think there is somthing wrong with your game.
Apr 07, 2009 | Video Game Consoles & Games
Put Escort passport 8500 X50 into calibration mode.
If you hold down the mute button (on front) and the two buttons on top...when you power up, it will reset.
Mar 20, 2009 | Passport 8500 X50 Radar Detector
Compass deos not point north
do a calibration. press the menu button while on the compass screen and select calibrate.
Jun 07, 2008 | Garmin eTrex GPS Receiver
Lens becomes jammed when taking pics.
this is the suggested way to contact them see the links on this page
http://www.nikonusa.com/template.php?goingto=inc_service
Jan 27, 2008 | Nikon COOLPIX L12 Digital Camera
Motorola Mobility MOTONAV TN20 GPS Receiver Logo
140 people viewed this question
Top Motorola Mobility GPS Experts
Are you a Motorola Mobility GPS Expert? Answer questions, earn points and help others
