Question about Philips Audio Players & Recorders
I have a Philips 877 Direct Control turn table, about 30 yrs old. Ran fine until recently. Will not start. Moter is ok, I can force it into reject mode.
SOURCE: haier HDP18PA
On another site, someone posted this: "I called (website), where it was purchased from, and they gave me the number for the manufacturer. Some standard troubleshooting did the trick and my dishwasher is working perfectly again. The troubleshooting involved tilting the dishwasher backwards at a 45-degree angle and letting any excess water drain out. They said ocassionally the water intake will be blocked and this process helps move anything that may have gotten in the way"
I was having the beeping problem too, and decided to give it a try, tipped it for a few, and found it to work!!! Hope this maybe helps!
Posted on Oct 17, 2007
SOURCE: Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
Posted on May 31, 2008
salsaurbana
  • 56 Answers
SOURCE: TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Posted on Nov 23, 2008
  • 4 Answers
SOURCE: powermate 5000 subaru moter the gen runs for 1 mn and shuts down
oil level is low???
Posted on Dec 19, 2008
  • 199 Answers
SOURCE: bow mounted pd55 trolling moter, 5 yrs old.
put the old one back on and see it the engine runs if so it is in the connection to or from the cable
Posted on Jul 02, 2009
After 7 yrs, suddenly the ********* cartridge is not recognized, no red light, why?
HP Officejet Pro 8500 will not recognize changed ink cartrid ...
h30434.www3.hp.com > Printers, Copiers, Scanners and Fax > Inkjet
Laptops & Tablets Laptops & Tablets .... HP Officejet Pro 8500 will not recognizechanged ink cartridge ..... I have a hard time believing that something that worked just fine until it ran out of ink, suddenly has a broken sensor. It's barely 2 yrs old. ... show any ink, replaced them all and after 5 minutes of 'thinking', ..it worked.
Epson cannot recognise a cartridge:16 ways to solve the ...? 6:33https://www.youtube.com/watch?v=bc04OM9ZRXkNov 4, 2013 - Uploaded by viandant5The red ink light remains on after replacing an ink cartridge. - The printer is not recognising one or more ink cartridges. ... Via Beverara 224/7 ... Printer cartridges not detected - How to fix - Duration: 2:41. by Thriftyink 102,951 ...Epson inkjet printer rejecting printer cartridges
Dec 21, 2015 | Office Equipment & Supplies
Oil pressure problems on Pontiac 1999 Bonneville
30+ years as an automotive certified master tech. It is ok. 30 lbs is more than most engines out there for a hot idle pressure.
Oct 06, 2014 | 1999 Pontiac Bonneville
My picture display is narrow and does not cover the screen.
Does the Genie box have screen settings in in? Sometimes hd will show in smaller screens. Makes the picture nicer. If you adjust the screen size with your remote the high definition "niceness" will not be there.
Jul 30, 2014 | Seiki Televison & Video
Just replaced speed control unit and saw still spins at very slow rpm, guessing 20-30. any other possibilties. any way to check if new control unit is no good?
With the saw unplugged, turn the saw blade.
If it turns easily with no hangups I would guess its the field.
When mine went bad the blade went backwards very slowly.
I replaced only the field and not the armature and it's worked fine for over 2 yrs.
Right now I have it apart to change an armature bearing which was completely frozen up.
Aug 29, 2011 | Bosch 4000 - 07 Electric Table Saws
I WANT A SUPRA TV REMOTE MODEL NO IS ST 21B55FT
Hello
You just buy one [PHILIPS CL 034], universal remote control. Supra is listed in its codes.
Codes are
0002 0809
NB: Switch OFF and ON your TV by its front panel power switch [NOT BY THE REMOTE HANDSET], each time, and wait for about 30 seconds, before try an other code.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
ok.
Dec 22, 2010 | Televison & Video
I need remote control
Hello
You just buy one Philips Universal Remote Control. Model number [ Philips CL 034]. JVC has been listed in its codes. I hereby send codes also.
0607 0204 0321 0508 0326
0993 0802 0108 0308 0715
Direct Code Entry
button.
flashes.
OK
Dec 08, 2010 | JVC AV-32020 32" TV
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
388 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
