Question about KitchenAid KSRG25FK Side by Side Refrigerator
Ice machine does not make ice
My water dispenser works fine but the ice machine does not is there some sort of troubleshooting guide i can see
  • 1,606 Answers
No guide that I know of .
Open the freezer door and see if the laser light on the right side , flashes twice , then pause , repeatedly . Close the flap on the left side , and the laser should stop flashing . If this is what occures , then the optics ( cut off of the icemaker ) are ok . If you open the freezer and no laser on the right , check the position of the "rake" inside the icemaker . Close the freezer door for about 1 min , and then recheck the position of the rake . If it hasn't moved , then the icemaker is bad .
If the light flashes 2 times then pauses , pour about 2/3 cup of water into the icemaker , and check later , to see if the ice maker has dumped the cubes . If did not dump , replace the icemaker . If did dump , and did not fill with water , then the water valve behind the refrig is bad . Also check the black fill tube above the ice maker fill cup , to see if it is iced up , keeping the water from going into the fill cup . If it is frozen , then replace the water valve , due to seeping ( not closing completely ) , causing the slight drip , to freeze inside the tube .
This is the only guide I know of and it's called an experience guide .
Posted on Sep 27, 2009
Ice maker does not work
You did not give much information to troubleshoot, but here is a try. Assuming that the fridge is running, freezer is cold and you get cotd water through the refrigerator water dispenser, and no water is spilling into the ice holding tray, the most likely culprit is either the ice level sensor (often a bar or wire of some sort), is either blocked or locked up in position to stop ice production - or some units have a switch to stop ice production - like for a vacation
Aug 06, 2016 | Refrigerators
Water dispenser & ice dispenser stopped working
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
The water line is clogged or water dispenser valve is blocked.Click this link below for troubleshooting:---
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
This will help. Thanks. Helpmech.
Oct 31, 2011 | Refrigerators
Ice maker is not working - not making ice - water dispenser is working fine
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
te95
Dec 07, 2009 | GALAXY Microsystems 25.4 cu. ft....
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water drips slowly out of dispenser, ice distribution is fine.
Hi, yes the water line could be starting to ice up; maybe defrosting the fridge will cure the problem. Mine has a coiled tube behind the lower drawer in the fridge, this is where the water line is chilled. Hope this helps if you've not sorted the problem already. Kind regards jb
Jul 02, 2009 | Whirlpool GS5SHAXN Side by Side...
Water dispenser and Ice maker not filling with water.
You need to replace inlet valve for the dispenser and ice maker .
Dec 09, 2008 | U-Line Refrigerator Ice Maker
Problems with Kenmore Side by Side Refrigerator
take the cover off of the ice maker. there are 2 plastic tabs in the middle of the gear on the ice maker. if one of those tabs is bent or broken, that is your problem. if the tabs are okay, check your fill tube in the back of your freezer that goes to your icemaker and make sure it is not frozen. if both of those are okay, then you may have an issue with your water valve. Joe
Dec 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice/water dispenser control panel
could be the dispenser board or the main board. hard to sort out without a meter. most likely the dispenser board but i have seen a dispenser board go bad and smoke the main board if that is the case you can damage the new component so check out the cost on the parts
May 07, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
KitchenAid KSRG25FK Side by Side Refrigerator Logo
433 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
