Question about Dell Latitude C610 Notebook
Dell D610 Screen Black, But Power Still On
Ok, I am very computer saavy. I build the things for crying out loud, but OMG I hate laptops. I've recently aquired a Dell Latitude D610, I'm working on getting a fresh power supply for it, but in the mean time, I want to conserve my battery power.
The problem is this: When I close the lid, the screen goes black (as it should if the little switch is working properly). I have set all of the options in "display" to "do nothing", and still it will not come back on when I reopen unless I press the power button to shut it down and then again to reboot. I have tried resetting the switch by pressing and releasing it with a flat object and I have gone through the BIOS and could not find anything suggesting that it would keep the screen off for any reason. Any suggestions?
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your isue,
 Thats the way these dells are, the standby mode sometimes puts it in hibernation.
Check the settings in the screen saver/ power area
If I have helped you pleae click accept
we can till post until the post expires
Thanks
Eric
Posted on Sep 27, 2009
My dell d610 wont boot up,and screen stays black,but the power lite comes on,and the screen flashes real quick then goes black is there anything i can do?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 07, 2013 | Dell Latitude D610 Notebook
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
My Dell Latitude D610 keeps shutting down
Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
Jun 30, 2012 | Dell Latitude D610 Laptop Computer -...
I accidently plugged in my Dell Inspiron 518 into a 220 v outlet without switching over the red tab on the power supply. I heard a loud boom and smelled smoke. I've since replaced the power supply,...
I really hate to be the bearer of bad news, but your motherboard may have been fried. The power surge was probably too much for it to handle, especially considering this isn't a custom build, so the parts inside of it are cheaper. Contact Dell Support and see if there is anything that they can do for you.
Aug 21, 2011 | Dell Inspiron 518 Desktop Computer
My dell D610 stopped working that is it ceases to function
If the computer doesn't turn on at all, it may be a power issue. Does it do the same thing whether you're connected to AC power or not? You may have a bad AC adapter, or the port may be loose so its not making a good connection.
Sep 04, 2010 | Dell Latitude D610 Notebook
Dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Mar 15, 2010 | Dell Latitude D600 Notebook
Dell latidude d610 wont start properly
Can you select "safe mode" from the boot menu? As much as I hate to recommend it, I think you should wipe the hard drive and reinstall Windows (I hope you backed up everything of value on your computer). If you can't successfully reinstall the operating system, then I'd say, in all likelihood, you have a defective hard drive which would need to be replaced.
Feb 11, 2010 | Dell Latitude D610 Notebook
Dell latitude d610 screen blackout all of a sudden and comes back to life after restart thanks for your help!
Check your power option. Under control panel. Make sure sleep or hibernation is disabled. Your laptop might be going into sleep mode making the screen black out and could not wake up from it.
Hope this helps
Dec 20, 2009 | Dell Latitude D610 Notebook
The screen on my dell laptop d610 sometimes will not turn on when starting the computer from standby. And never turn on if running off the battery.
Don't you just hate when your trusty laptop slips into a coma and won't resuscitate?
Jen, the good news is this will be easy to correct. First, I recommend you go into your operating systems control panel and configure your power save settings to avoid going into a stand-by state whether plugged in or running on battery unless as a last resort when reaching critical power depletion on battery mode. Shut your computer down when you are finished and leave it at that. If The you want to leave it running unattended, its okay to configure the monitor and hard disks to shut down after a period of inactivity, b4t on laptops, standby mode really doesn't seem to enjoy a reliable and consistent track record on numerous laptop models. Check your systems bios settings on start-up by pr goes into W5nd6ws by pressing the (delete key). Disable any power management settings in the bios then save and reboot.
If you must for some reason, feel compelled to keep using stand-by mode... when the black screen issue rears its ugly head, hold down the 'Fn' key and press 'F4' a couple of times... this worked for me until i got tired of doing it and disabled stabdby.
Hope I was able to FIX-YA! with this post. Please take a minute or five to eloquently detail the range of emotion and feelings you experienced when tempest-tossed, you found safety and calm in the smooth glass-like pools of knowledge here in Geek Harbor.
Aug 12, 2009 | Dell Latitude D610 Notebook
Dell latitude d610 dark screen
there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly  you should go to service and need to be changed INVERTER.
pls rate
May 28, 2009 | Dell Latitude D610 Notebook
Dell Latitude C610 Notebook Logo
348 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
