Question about Kitchen Appliances - Others
Bread is rising over bread maker - I l live in Darwin and have been using Laucke Bread Mix the 600g pack. I have had the bread machine for a couple of years and now this build up season (very humid) the bread is rising over the bread maker. I have tried using less yeast and a little less water. This time last year there was the same problem if I used the time delay. This year it doesn't matter if I use the time delay or not the bread just grows and grows. This morning I only put 1 teaspoon of yeast, a little olive oil and 350g of water. HELP
SOURCE: half sized dish shaped wholemeal bread
Hi
I had a similar problem in making sourdough bread and noted on some websites the importance of correct salt and surgar quantities for rising. I increased my quantities to correct the problem. Of course the recipe was different but it may help.
Posted on Jan 29, 2008
gregstobbe
  • 56 Answers
SOURCE: Yeast...
you will want the rapid rise yeast. you instruction book will also tell you what yeast to get for the type of bread you are going to make.
Ps. Dont forget to rate the solution. Thanks
Posted on Dec 28, 2008
SOURCE: Bread is falling during baking
I had this same problem. It has to do with the amount of water and the amount of yeast you are using. I decreased my amount of water to 1 cup ( of course it depends on your recipe) and I also was using rapid rise yeast which calls for a less amount (usually 1/2 tsp less than what the recipe calls for). I did experiment with the recipe until I got it just right. Good luck. Carrie
Posted on Jan 16, 2009
SOURCE: bred does not rise
Is the yeast and the water both at room temperature? If either is to hot or too cold it can be a problem.
Posted on Aug 08, 2009
  • 557 Answers
SOURCE: The bread never rises. I have tried types of
yeast must be in water around 104 degrees f with some sugar added
Posted on Oct 20, 2010
Are there more recipes for my Crofton bread maker. I'm afraid that I haven't had a lot of good success with it recently. I have used Wrights complete bread mixes, they always dip in the middle
Hello, Julz -
Instead of looking for more recipes for your Crofton bread maker, or any other bread maker, I looked for information as to why the bread made with a bread maker would collapse on top.
The answers I found on this online baking formum:
http://www.thefreshloaf.com/node/9725/bread-machine-loaf-collapse-when-baking-starts
may prove instructive.
To summarize, some of the causes and remedies for bread maker bread collapsing on top:
- You may reside at a high altitude and have not adjusted the recipe so that it does not over-proof [over-rise]. Cut down on the yeast, sugar, and salt.
- Even if you are not at a high altitude, try a recipe with reduced amounts of yeast, sugar, and salt (try reducing the amounts by 1/4 to 1/3)
- Use the dough mix cycle; Then turn the machine off and let the dough rise a little less than the recipe calls for; When you see the dough has risen turn the machine on to bake.
- If your bread maker allows,.reduce the amount of time between rise and bake
If you want additional bread maker recipes, you will find more here:
http://allrecipes.com/recipes/338/bread/bread-machine/
I did find a PDF document (Adobe Reader software - free) for a model of a Crofton Breadmaker, model MD 8505. In case you do not have a manual for your machine. The manual I found has information on how to make adjustments for altitude (page 22) and other adjustments to make (pages 23 - 24), including what may cause the loaf to fall while baking. This is the link to the manual:
Best wishes.
Feb 06, 2018 | The Kitchen Appliances - Others
How to reduce the ingredients for bread packet mix. I made the recipe and it overflowed the machine and tripped my power
You can reduce it proportionally. For example, if you only want 1/2 of the bread, you will have a 1:2 ratio. 240:480, 300:600, 1/2:1
Mar 28, 2015 | Breville Vitesse VIN118 2000 W Steam Iron
Use wooworths elevation breadmaker
A bread machine that works correctly goes through these basic cycles. If your machine did not do this then it is broken and you need to replace it. The cycles are, Mix.....Rise....Mix......Rise....very short Mix of a few seconds....final rise of over 1/2 hour......bake of approximately one hour......I sell good used machines that will come with a full money back 30 dayguarantee (shipping, everything) You can reach me at daryl441@msn.com or my website breadmachineshelp.com
Jul 02, 2013 | Kitchen Appliances - Others
Bread does not rise
Make sure you are using the correct type of yeast. The old style active dry yeast is not as good. I recommend that you try Red Star Quick Rise Instant Dry yeast. Also be sure to store the yeast in the refrigerator. And, if you are not using a mix, try King Arthur Flour, it costs a bit more, but their tighter standards means you get more consistent results. They also have bakers who will answer your questions for free at 802-649-3717.
Nov 16, 2012 | Sunbeam 5891 Bread Maker
The bread starts rising and than falls in the middle in the last 20 minutes of baking. What is wrong?
Rising bread is caused by carbon dioxide bubbles being created in the bread by the action of yeast on the sugars in the mix. If the rising stops early, allowing the bread to fall it could be one of several things that cause the carbon dioxide bubbles to stop pushing up the bread. Any of the following could be the cause:
- insufficient sugar in the mix to feed the yeast.
- sudden drop in temperature, slowing down the process, maybe caused by opening the lid to check
- mixture that is so thick that the gas production struggles to overcome the elasticity of the dough
- try adding a little more water, or more sugar, or changing the flour. Avoid opening the machine to check on progress.
Mar 05, 2011 | Sunbeam 5891 Bread Maker
The bread only rises about half way.
After its mixed the ingredients and before it cooks, it should sit for a while to allow the mix to rise. Check that the heater is on in this period, otherwise, if its cold, it wont rise
Feb 14, 2009 | Betty Crocker BCF1690 Bread Maker
Not rising and meally texture
Hello psaulina,
When I hear of bread not rising, I always suspect the yeast first.
You said you've used the hawaiian bread mix multiple times. From the same container? Or have you tried multiple different packages (hopefully from different production lots)?
Back in the day when my Mom was baking bread on a regular basis, she'd occasionally get a bad batch of yeast, and the bread would be the weight and consistency of fruitcake, but with somewhat less flavor. (We ate it anyway).
If your yeast is separate from the bread mix (don't know, you didn't specify), you need to first check the quality of your yeast. If the yeast is too old, or just bad, your bread won't rise.
To test the yeast, mix a sample in warm water (~105 deg. F) and add a little sugar. If the yeast is good, it should start forming bubbles. No bubbles, time to get new(er) yeast.
If your yeast checks-out, then you need to see if something in the machine's process is overheating the yeast too soon - - the yeast's fermentation process creates the carbon dioxide (CO2) bubbles that causes the bread to rise (sort of like inflating a balloon, if you like). If something is killing the yeast (e.g. too much heat too early in the process), it won't react and create the bubbles.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Good luck, and thanks in-advance for your rating,
Jon
Dec 26, 2008 | Breadman TR2200C Ultimate Bread Maker
Kitchen Appliances - Others Logo
19 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
