Question about Sceptre S1902D 19" LCD Monitor
Sceptre S1902D LCD 19" Monitor... When initially powered up, the screen is on for about a sec or two, then goes black. If I turn the monitor on and off quickly, it usually comes on and stays on after the 4th or 5th attempt. Is this indicative of a bad inverter board or bad fluorescent backlights? Thanx
  • michale630 Sep 27, 2009
    Just further info on the above problem.
    I have pulled the monitor apart and looked at the Power PCB and the other PCB. There doesn't appear to be any blown caps. All the caps look in good shape.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 178 Answers
Good wholesale price fluorescent board.
Posted on Sep 06, 2010
Will it support TV (rca) a/v input through vga
That should work because a/v and vga are analog.
Dec 16, 2013 | Sceptre S1902D 19" LCD Monitor
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
I powered the monitor off 1 evening after watching movies I was useing the monitor as a second monitor on computer doing multi tasks, but now when i turn it on i just get a black screen it lights up at...
Your computer may not be seeing your second monitor. Go to your display settings and see if you computer is seeing monitor 2.
A fast way to check is to plug this monitor in as your primary on the computer to see if it works.
Mar 09, 2010 | Sceptre S1902D 19" LCD Monitor
My sceptre 30" lcd TV monitor turn on a few second then turn off only the sound is still on.I try to turn on/off many times and some time it works some time it doesn't. Could you please help what is the...
It can be the problem in the backlight inverter board or the power supply problem. You need to open it up and start looking for bad caps with bulging top first. Post back what you see inside. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 06, 2010 | Sceptre S1902D 19" LCD Monitor
I've got a Sceptre 19 in monitor with the typical "on for a sec and goes dark". I removed the 6 screws on the back of the case but obviously there is a further step thats alluding me...how to you crack the...
You need to use a plastic scribe to run around the edge of the monitor seam. A plastic scribe is a tool that looks like a knife, but it is not really sharp. Pry into the seam on the monitor and gently but firmly work around the edge until it pops apart.
Nov 06, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitors work well for a while then have trouble booting up
It is a symptom that like T.V's usually manifest before they go busted. I also had that kind of problem before. Then after 4 to 5 months, my monitor just has a black screen. It powers on, but still a black screen.
Sep 04, 2009 | Sceptre S1902D 19" LCD Monitor
My sceptre monitor S1902D won't turn on just stopped
If the monitor has no power at all then you have a dead power board, or a broken power cord, test also a different wall AC outlet.
If instead there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Mar 06, 2009 | Sceptre S1902D 19" LCD Monitor
Problem with sceptre monitor
I have repaired a few of this model by replacing the failed capacitors in the power supply.
Monitor Mike
Dec 23, 2008 | Sceptre S1902D-4 Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
BLANK SCREEN
was she playing with the keyboard. ??
She/he may have shut off the monitor from the keyboard. look for a little picture of the monitor.
Sometimes you need to hit fn (function) key and the display key to toggle it on
Robert
May 08, 2008 | Sceptre S1902D-4 Monitor
Sceptre S1902D 19" LCD Monitor Logo
408 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
