Question about Midland 75-822 40-Channels Handheld CB Radio
No audio output with internal OR external speaker. Any suggestions? Could it be audio circuit and is this a common problem? Also need schematic for 75-822.
  • Anonymous Mar 17, 2014
    I get audio from the speaker jack (headphones/external speakers), but nothing from the internal speaker. Just bought it. Arrived new today. Any help would be greatly appreciated.
  • 211 Answers
Unfortunatly this is a common problem. I have found that the mic switch ( PTT Switch ) doesn't always make good comtact internally ( You might spray some contact cleaner in the switch ) and also you might look close at the speaker jack in the radio. It may have broken contacts ( the lead broke loose from the board ). Resolder them and it should work. Good Luck
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Sony wega 2009 tv. No Audio but picture. Internal speakers on, no luck. Tried external speakers, turned off internal speakers,still no luck. Suggestions? Is it audio components or board bad?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 05, 2017 | Sony Televison & Video
Audio went out has a great picture but no sound
Make sure that your speakers on set are turned on. If they are and still no sound then you have developed a problem with the audio board and/or amplifier.
If you have audio outputs check to see if you can feed that output to an external amp. If the external amp works then the issue is with the internal amp of your tv. If external does not work either then the problem lies with the audio circuits that precede the amp of your tv..
Sep 04, 2015 | Mitsubishi Televison & Video
HP Pavilion DV7-1135nr laptop internal speakers won't play
try installing proper drivers for the AUDIO CARD! the orange led only indicates the HTK HOTKEYdrivers are working properly, it does NOT says a thing about audio card drivers! so i suggest you to install proper drivers for audio playback!
Apr 05, 2013 | Computers & Internet
Kdl-32v4000 sound
Check the speaker first. Check if there is any sound output comes from the audio out terminals at the back of the TV, by connecting them to any external audio out devices; such as an amplifier or so. If there is audio output comes from the external source such connected, and no audio output from the TV; since the speakers are good, the fault is with the audio output section circuit inside the TV. If there is no audio output from the external sources too, the fault is with the audio processing section circuit at the main board. If this is the case, main board is faulty, and should be replaced.
Aug 07, 2012 | Sony Bravia KDL-32V4000 32 in. LCD TV
No sound in bravia tv
for a better answer a model number is needed:
Speakers are not switched off in audio menu
Volume is not muted either on the set or a cable box if being used.
one of these or if you put your ear directly to the speaker/s and hear a buzz or very low sound---problem in audio output circuit.
A few sets also have internal/external speaker switch............
Mar 25, 2012 | Sony Televison & Video
How do i connect external speakers
Hi, Unfortunately it has no audio output jack / connector. But if you want to enabling audio output just tap it on internal speaker wires ( make it parallel or disconnect internal speaker and use your external speaker).
Regards, vote please, Jay
Jan 19, 2011 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
It says, that the ViewSonic PJD5122 SVGA DLP Projector has a built in 5 watt speaker. Does it? Because when i try to hook my xBox into it, there is no sound when the voume is all the way up. Also, when I...
You have a 3.5mm Audio Input jack for external audio in. ( Not Speakers) The Audio Output jack is for connecting that to a stereo system which is the best way to go. So, what you want to do is connect your xbox audio out which is probably a rca jack to the projector. I believe you will have to buy a y-adapter ( 3.5mm male > double rca fe-male) then use the standard rca audio cables. You don't plug speakers into that unit, I hope you haven't damaged the audio circuit. You might have a external audio switch within the menu of the projector to switch from internal to external audio source,,, look for that.
Dec 03, 2010 | ViewSonic Televison & Video
The sound on my Dell laptop has suddenly gone very tinny and distorted. Does anybody know what the cause may be and how I could fix it without calling Dell in India?! Thanks
I would use the audio output of your netbook to supply signal to any external audio system so you can determine is it is an internal circuit problem or simply a failed speaker. If the distortion is present in the sound output from the external system, then a circuit in the netbook has failed. If it isn't audible in the external system, then a junky speaker has failed in the netbook.
Oct 24, 2009 | Samsung NC10-14GW Notebook
Looking for a schematic diagram
It would be less trouble to disable the internal speakers from the television's setup menu and connect to a set of powered speakers or a receiver using the built-in audio outputs. It will be a challenge to get good sound quality and levels from the headphone jack.
Apr 26, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Midland 75-822 40-Channels Handheld CB Radio Logo
180 people viewed this question
Top Midland Radio Communications Experts
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
