Question about Frigidaire PLMV169DC Microwave Oven
My microwave is a 2005
Just completely went blank. cant find any fuse can you help me.
  • 1 more comment
  • jlyon Dec 23, 2007
    I did not see any fuses on or around control panel. Is there somewhere else it might be?
  • jlyon Dec 25, 2007
    I replaced the switch kit,monitor,with c/t fuse and I received 0 results. I am wondering if it could be the transformer,power? I pulled out the key pad and did not see anything with "4A". And if you are talking about the door sensors, yes I did see those and part of the switch kit I ordered was one of those.
    Please help me.
  • jlyon Dec 26, 2007
    what do you think about the possability of the problem being the control board. And I still see nothing with 4A or 10A. There is something on the board that is about the size that you describe but it says TDK on it and is saudered to the board. Could this be it.
This is a possibility. TDK makes a number of components. Is there a label screened to the board saying what it is? It is always possible that the board is bad. The transformer can be tested. All transformers are a/c. Try this first: Unplug the unit. Using a multimeter set on ohms, low scale, check across the plug. You should get resistance. If op4en (no needle change from open probes), it is a fuse you haven't discovered or the transformer. Get to the wiring for the transformer. Test across the primary (110V) side. Some resistance reading now indicates a bad fuse. Open circuit is a transformer problem. Disconnect the transformer on the other side from any least one connection. Perform the same test. You should have some needle or numerical reading. No movement...bad transformer. I hope this helps. If not, get some assistance.
Posted on Dec 26, 2007
They are always inside the keypad enclosure. If they are on the board, they are labeled with something that says "4A" or something like that...they may not look like a fuse. Did you find the sensors?
Posted on Dec 24, 2007
  • 833 Answers
Jl, first, are you sure that you have power? Plug something else in to check. Also, unplug the unit, wait a full minute and repower. Sometimes this resets the units. Second, fuses are generally located inside the keypanel area. With the unit unplugged, remove the screws holding the panel on. Inside, you will find at least one fuse. You will also find thermo sensors. They are black, about the diameter of a dime and 3/8 inch thick with two wires coming out of them. Check them for continuity.
Posted on Dec 19, 2007
  • Robert Hirst Dec 25, 2007
    t might say something like might be 10A . It could be the
    transformer. Door sensors are not your problem. Over temp sensor could be. They are about the diameter of a dime, black and 3/8 inch or so thick attached to the keypad side of the cavity wall. Two wires coming out. If they go bad...nothing might work. Use a multimeter to test them.
No power... No lights or Fan. The 110 outlet has power. I tested it. The display is blank. I have unplugged the microwave but I had the same results. Is there a fuse in the microwave?
Most microwave ovens do have a line fuse. I can't be completely sure if your does, since you did not supply a model number. If the cover is removed, the fuse should be close to the power cord. Hope this helps you.
Mar 13, 2011 | Whirlpool Microwave Ovens
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave made a popping noise, then it went blank, and it still has power to the plug. Does it have a fuse inside?
Yes, there is a fuse inside of the microwave...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
Dec 24, 2010 | Goldstar MV-1526 Microwave Oven
My Sharp R-1460 Microwave Oven blanked out on me. I replaced the fuse and all lit up. When I went to turn it on to run, it blanked out again. Can you direct me to what the priblem might be?
I suggest the door switches are probbaly faulty. A job to say which one but you may find that it is caused by contamination or condensation.
Hope this helps.
Oct 28, 2010 | Sharp R-1460 Microwave Oven
My LG microwave went completely dead. I is only 3
under the outer cover,its either a 10-15-or 20 amp ceramic safety fuse avail at most hardware stores, the amp rating is on the side of the fuse, if the new one blows then either the H.V. diode/capacitor or the magnetron can be suspects
Oct 03, 2009 | LG LMV1630ST Microwave Oven
Kitchenaid Microwave went blank
Is there a reset button or something I am not aware of?
May 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Mcb780w won't work
Chances are its the fuse on the circuit board. You will have to remove the outer shell of the unit to access it.
Feb 27, 2009 | Magic Chef MCB780W Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
103 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
