I can't make a playlist on my sansa and the go list that is already on there is full so i tryed to make another and it diddent ework i thot maby it's the usb format because it also wouldn't let me look at all of my songs so i changed it and i can see them all and there is a folder for playlists and i used it but when i lokk in my playlist folder it's empty exept for the go list so i look at the all the other places on the sansa to see if i can find the words that i used to make it can't find it any where. and i want to make a new playlist so ay help would be great!
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automaticconnect sansa and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode. Update software from this link.. (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) and install the software before you recover Deleteing Playlist: Open my computer double click my music Here you should find the folder my play list double click and delete file .wpl or .m3u these are the playlists....You can also go to search type .wpl enter when located delete remember where file was located...Windows Media Player will find them also and you can delete from there.. (Library)
Creating Playlist To create a playlist for Windows Media Player, follow these steps: 1. Launch Windows Media Player. 2. Clear the List pane by clicking the Clear List pane button. 3. Click the arrow below the Library Tab then select Create Playlist. 4. Type in the name of your Playlist. Loading Content 14 5. Click Songs from Library then drag them from the Details pane to the List Pane. 6. To rearrange the songs, drag them up or down in the List pane. 7. Click Save Playlist. Transferring Playlists To transfer playlists to your Sansa player, follow these steps: 1. Connect your Sansa player to the computer. 2. Select Sync digital media files to this devices using Windows Media Player on initial connection. 3. Right-click on Your Sansa Player, then select Set Up Sync. Loading Content 15 4. Select Personal Playlists from the drop down menu on the left pane. 5. Highlight the playlists you want to transfer to your Sansa player, click Add, then Finish. 6. Synchronization will start as soon as you click Finish. To see the Sync progress, click on Sync Results.
There is a well known problem with the sansa regarding playlist..I am sure sandisk is working on a firmware right now that will fix the issue you are having..
connect your mp3 player to your pc... find those unnecessary playlists and just delete them... if it doesnt get deleted then try to format the player and make it fresh... add playlists that u wish later :)
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB". 2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode - Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list - Select the Sync tab and click "Sync settings" - Check "Synchronize device automatically" - Set "View" to "All Playlists" - Place a check next to the playlists they want to transfer to device - Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
yes you can create playlist using WMP11...
To create playlist using WMP
1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button .
Drag items from the Details pane to the List pane to add them to the new playlist.
To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
To rearrange items, drag them up or down in the List pane.
To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
To play the playlist in the List pane, click the Play button .
To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Computerrep
The shuffle feature shuffles songs randomly - no way to change the order.
On the Sansa Clip, you have to make the changes to the song order in Windows Media Player first, before you transfer the playlist to the Sansa, using the advanced tag editor function; change the track number. If you have already transferred the song(s) over to the Sansa, you must delete the songs on the Sansa first, or else it will not accept the playlist transfer with the new track order. You can always go back and change the track numbers that are stored in your WMP library after you have transferred the playlist to the Sansa.
Create your playlist with winamp and then copy it over with the songs listed in the playlist. You can make as many playlists as you like and they will show up under "playlist" on the screen
