Question about Refrigerators
Kenmore side by side compressor trips the thermal overloads? When the system is reset it runs and makes ice for about 16 hours then gets warm.. Repair guy charged me 85 bucks to clean the coils...don't really trust him. Can you help?
  • Mike Smith
    Mike Smith May 11, 2010
    Dirty coils will definantly cause the overload to trip , as will a compressor cooling fan not working . Did the repair guy , take an amp reading of the compressor , after cleaning the coils ? Above 3 (compressor running amps) , is an indication of the compressor not having much life left .Does the refrig still click off , after the coils being cleaned ?
  • 146 Answers
Your condenser coils were probably very dirty and covered with dust, which TRAPS heat and does not allow your unit to get rid of its heat - this causes the compressor to run excessively. Did he also check door seal gaskets and over frost on the evap (defrost issues)? Did he take measures on the compressor as well ?
What a rip-off - cleaning condenser coils is something you can do yourself with a special brush - you should have spent this money on having him check other problems.
Posted on Sep 27, 2009
. kenmore side by side blows warm air, after
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 30, 2011 | Kenmore Side by Side Refrigerator
I have a Manitowoc QD0212A 120v. It makes ice, but after the bin gets full, it appears that the compressor does not run to cool the ice box. Is there some type of relay or solenoid that could be bad?
Try cleaning the radiator for the ice box compressor it could be tripping it's thermal overload switch, if that doesn't work check to see if the termostat setting is in the range for the compressor to turn on when the ice starts melting.
Jun 29, 2011 | Manitowoc - QD-0212A/115-1
Ice maker just stopped--red light near on/off switch is flashing
unplug the unit for 5 minutes and plug in again and see if it clears the memory and resets
Aug 01, 2010 | Kenmore 53642 / 53644 Side by Side...
It appears that the overload keeps tripping on the compressor
Almost certainly the compressor sounds to be faulty. That alarm is possibly the warning that the temp. is not correst. I would switch the system off for approx. 1 hour then retry. if it starts to clck again then it proves the compressor is faulty.
Sep 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor runs 12 seconds then down 2-3minutes
It sounds like you have a blockage in the refrigeration system. This would cause the compressor to overheat and ultimately trip out on thermal overload.
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Only fan working on my side by side
wait for about 4 hours and plug it again. let the compressor cool down. it could have tripped it's thermal overload.
then observe if the compressor would start. it would vibrate, make a little bit of noise and heats up.
if it is trying to start and can not start, then it could be broke already.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore Refrigerators
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Kenmore side by side fridge
It sounds like your compressor is having trouble starting, and over heating. this could be one of the following
  1. start relay is bad
  2. run capacitor is bad
  3. compressor run/start winding burned out
Try unplugging the unit for a few hours to let the compressor cool down. Then plug it back in and see if the compressor starts. If it starts after it has cooled down, then it is likely out or low on refrigerant. If its low or out of refrigerant it will run until it over heats, then kick out on thermal overload. This is because there is not enough cold refrigerant being pulled back into the compressor to keep it cool.
Jan 28, 2008 | Refrigerators
Frigerator runs constanly till compresser gets to hot
Sounds like it might be the thermostat
sensor bulb is defective see if you can
turn the refrigerator off with the thermostat
the defrost heater is supposed to heat up
enough to open the defrost thermostat
Make sure the defrost timer works to
turn on lhe heater & turn off the defrost tstat
turn the power off and check the tstat & defrost
heater for continuity check to see if tstat open
and closes when you turn the knob,
if you remove the tstat you can check the
bulb in ice water and warm water aborv 40
to see if tstat cycles on and off
Nov 26, 2007 | Maytag MSD2650H Side by Side Refrigerator
Refrigerator and freezer
Does the compressor click on and off every minute or so and is hot? That would likely be tripping on a thermal overload due to not being able to start (bad motor starter on the compressor). If the compressor is running normally and warm then you may have a froze up coil. Take the lower rear back sheetmetal cover off the inside freezer section and look at the coil. If it's frozen block of ice basically the defrost cycle is not working and the ice has blocked the air flow through the unit. (could be bad defrost heater, defrost timer or defrost t-stat). If the compressor is running normally and warm and you see no ice or even frost on the coils then you have a sealed system problem that usually means most if not all of the refrigerant has leaked out of the system (or a blockage/restriction in the system). This would be the worst case since it means a whole bunch of money to repair. Let us know what you find out and we can have a better idea on what to recommend.
Nov 23, 2006 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
