Question about Heavy Machinery
Throtle linkage diagram for a 5.5 hp tecumseh
Throttle linkage diagram for a 5.5 hp tecumseh chipper
SOURCE: 5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Posted on Mar 20, 2009
bbreton
  • 437 Answers
SOURCE: location of governor linkage and throttle linkage
Try going to searspartsdirect.com. You can put in the engine number 143.955016 in the model search and it should give you a parts list and diagram for that engine.
Good Day.
Brian
Posted on Nov 06, 2009
Testimonial: "Thank you!"
  • 468 Answers
SOURCE: 5 hp briggs & stratton on a chipper/shreader
if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
Posted on Feb 01, 2010
  • 55 Answers
SOURCE: 5 HP B&S RUNS AT IDLE BUT WHEN ADVANCED TO FUL...
It could be the linkage, but the most likely problem is the throttle has gummed up in the idle position. Put thin oil or spray carburetor cleaner on throttle and move it back and forth to work it loose. I've seen it many times after an engine sits for awhile.
Posted on Sep 09, 2010
  • 640 Answers
SOURCE: need new air filter for
You can look up the air filter with the model number and order it over the internet from a website such as partstree.com, but there are others. Or, you can get the model number and go to your local small engine repair and parts shop. Mine had it on the shelf. If your chipper/shredder is like my 8 HP Craftsman with a Tecumseh engine, then as you are looking at the engine, look on the left side of the shroud or cover and way down low on the curved portion is a label with the model number on it.
I hope this is helpful for you.
Posted on Aug 24, 2011
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
Have a Troy-Bilt Chipper/Vac model # 47282 5hp sp, the Carburator needs to be replaced, I cannot find a part # for it, or where one can be purchased, please help
I believe the carburetor part number for your model is 632631. I have the same TroyBilt chipper/Vac. It has a Tecumseh H50-65582W engine. A good parts diagram can be found at
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H50-65582W-PARTS-LIST.pdf
If this is the right part, you can buy it at Jacks Small Engine parts for $79
Good Luck!
Dec 12, 2010 | Troy-Bilt Chipper Shredder
Tecumseh TVS90 43710M 3.5 HP enginge. I was
the rule of thumb applies to your certain problemif you carefully inspect the throttle plate you can view which hole it belongs in by visually looking for any wear or paint removal around the holes the one with wear of use will be obvious
Jul 30, 2010 | Garden
5 hp b&s runs at idle but when advanced to full throttle it stays at idle. Suspect linkage problem . . . Any answers?thanks jim from lafayette louisiana
May 21, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Tecumseh HM80 engine, new carb, won't run
Not the solid state ignition. If this were the problem the engine wouldn't start at all. There is some adjustment needed to the carb but without more info, I'm not sure what.
Jun 17, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Location of governor linkage and throttle linkage
Good Day.
Brian
May 02, 2009 | Troy Bilt Walk Behind...
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Heavy Machinery Logo
1,585 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
