Question about Air Hogs Havoc Heli Helicopters
Spins clockwise and goes down to floor within just a couple of seconds, have no time to adjust anything, have full charge, it is new just out of box, I am new to this ( havoc heli ) airhogs Take off from holding it about head high
  • 3 Answers
First try on a smooth surface..throttle alil which ever way it spins trim
Posted on Nov 11, 2009
2002 Jeep Liberty heater works, but defroster blows cold air
on all cars made
(you can read the FSM at any time and see exact way and tests)
1: damper stuck or its actuator bad. ( 3 kinds uses on all cars)
2 ;controls to damper actuator bad.
3: wires between both faulty.
3 types are motor, vacuum servo and cable.
you have 2 of the 3.
the blend is a motor actuator
the recric is vacuum servo
the motor types are very hard to test, read the FSM.
ill post the calibration
quote
Use this procedure to ensure that the A/C-heater control is correctly calibrated to the blend door actuator. If the calibration is not correct, the heating-A/C system may experience a condition where full heating or cooling capabilities cannot be obtained.
Manual calibration of the A/C-heater control should be performed if the blend door actuator is not functioning properly, or if the temperature of the conditioned air is too warm with the temperature control in the full cold position or too cool with the temperature control in the full hot position.
NOTE This calibration procedure can only be started within the first ten seconds after the ignition switch has been turned from the OFF position to the ON position. Make sure that the battery is fully charged prior to beginning the calibration procedure. NOTE The length of the pause made at each end of the temperature control rotation (sweep) is important. 5 seconds) or too long (greater than 1.5 seconds).
  1. With the ignition switch in the OFF position, move the temperature control to its middle (12 o'clock) position.
  2. Turn the ignition switch to the ON position (do not start the engine).
  3. Within 10 seconds of turning the ignition switch from the OFF to the ON position, perform the following rotations (sweeps) of the temperature control.
    • From the 12 o'clock position, rotate the temperature control counter-clockwise to the full cold position. Pause one second.
    • Rotate the control clockwise to the full hot position. Pause one second.
    • Rotate the control counter-clockwise to the full cold position. Pause one second.
Oct 05, 2014 | 2002 Jeep Liberty
I have audi A6 2.4 model 2006. When I start the car in morning, the battery sign appears after a couple of seconds. But when I accelerate a bit it goes away. The normal position of the rpm should be about...
Afraid not. Although the light goes out it still may not be charging very little charge will put the light out. the other reason I feel it's the alternator is instead of rpm increasing it should decrease as a properly charging alternator should pull the engine which should decrease the rpm
Aug 10, 2014 | Cars & Trucks
1994 ford ranger 4x4 4,0 it idles good but when going down road the check engine light comes on within 20 seconds acts like it is flooding out loses power let off for a second and then runs good for...
It should have a code stored. Some places still carry the scanners for OBD 1 Fords for around fifty bucks. Without knowing anything else about the truck or what codes you have, it sounds like you have a bad throttle position sensor.
Jan 05, 2011 | 1994 Ford Ranger Supercab
I have a 77 Toyota PU. New Clutch installed. Slave and throughout adjusted properly. Adjustment under dash adjusted full out. Still I have to jam the clutch all the way to the floor and barely able to get...
if it worked good before the clutch kit was installed , but not after then the clutch installation is incorrect
probably find the the clutch plate has been installed incorrectly
with a correctly fitted clutch kit , there is no necessity to change pedal height or anything else
Jun 23, 2017 | 1983 Toyota Pickup
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
I am converting from natural gas to l.p. gas and i cant get the oven flame adjusted properly to a nice blue flame . when the flame ignites it is perfect for about 5 to 10 seconds then the gas seems to...
Tighten down the nut on top the safety valve till it bottoms out. Then adjust it. The air shutter needs to be adjusted as well. You must do this while the oven is lit. The flame needs to creep no further than half way up the spreader. Ye must get the proper air to gas ratio and the only way to do it is to tinker away at it while the oven is lit.Crank down and flip machines are very simple to convert. NOTE: new gas safetys do not come factory set. They come tightened down (b Turning the orifice counter clockwise allows more gas , turning it clockwise allows less gas. Since the bi-metal safety is a slow opener that explains why you have a nive flame to start and then as time goes by the flap opens and allows for an overshoot of gas. tighten the valve clockwise to get the flame set as soon as you notive yellow. By the way I am sure a propane guy from your supplier would be willing to help you get it in tune if you feel a bit shakey about laying on the floor and adjusting the flames on an oven.
Apr 09, 2009 | Kitchen Ranges
LG Washer WM0642HW: Not enough water
Turn clockwise the water level sensor set screw a half turn "clockwise" under the top of the machine lid.This is the only way to rid yourself of the WICK WATER RUB WASH METHOD that is just terrible. Especially with a full load ! BELIEVE ME. I really wonder if consumers who have the WM0642HW earlier produced version with the nozzle spray system in the top of the door seal are having these troubles?. Mine is a 2009 verson of the WM0642HW, No Forced Water Recirculation. ( Discontinued) and how it was preset for fill at the factory made it perform terribly. Only after i adjusted the water level sensor does it perform well the first time around. Have yet had to rewash anything since the adjustment i made for the fill level. Good Luck.
Nov 09, 2008 | Washing Machines
Air Hogs Havoc Heli Helicopters Logo
978 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
