Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Stalls when hot
I have 2 149's. I put new points in both. After mowing a short time, 20-30 min, the engine starts to knock, sounds like it's trying to lock-up. Smoke comes out of oil filler tube, and engine quits. After cooling off, it will start immediately and run until it gets hot.
  • 867 Answers
It is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Posted on Sep 27, 2009
  • bozcro
    bozcro Sep 29, 2009
    the blinked out word is re tard , opposite of advance
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
May 17, 2017 | Cars & Trucks
Noisy vibration under car when started up, then stalls when put in gear. Clears after running engine for few mins
Sounds possibly like big end trouble, is there any knocking att all. Is the vibration accompanied by any new/unusual noises please. Add details and resubmit the query
Jun 17, 2015 | Cars & Trucks
99 F350 7.3 RUN 1 MIN SHUTS OFF CHANCHED FUELPUMP STILL RUNS 1 MIN SHUTOFF.
When it fails do you still have spark at the plugs? Sounds like and ignition module or coil to me.
Apr 14, 2015 | Ford F-350 Cars & Trucks
Hi, I have a John Deere Z225 with an 18.5 Briggs
Although, this does sound like a fuel issue due to past experiences I want to say the problem might not be fuel at all, but before we go that route try one thing. On that particular model I believe the gas cap is vented, if so try running it till it acts up, then remove the gas cap for a moment and see if the engine returns to running normal, if not I believe your coil is going out. I have seen alot of these engines recently where the works fine but when the get hot they quit functioning all together or only function part of time which in your case would indicate why it is missing and fowling the plug. When these tend to do this after they cool back down they function properly again until they get heated up again. I hope this helps you.
Oct 03, 2013 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
May 14, 2010 | Garden
Mower stalls out after about an hour of run time
A few possibilities
1. If engine runs hotter than normal it can eventually heat up the carburetor to the point that there is a vapor lock. Blockage caused by gas bubble: a bubble of vaporized gasoline that blocks the normal flow of fuel. Problem goes away when things cool down. If that is the problem, you need to solve overheating problem. Since you have changed the oil, might be something blocking airflow to the flywheel which has the cooling blades on it. Or cooling blades are filled with debris. Make sure vent hole in gas cap is not blocked
2. Could be bad coil, or condenser causing the windings to act up when they are hot and have expanded they short out (kill engine) on their own casing. After they coil and shrink, they un-short themselves.
May 14, 2009 | Garden
Car starts cold start stalls after short time
Sounds like the Idle Air Control Valve which is a dealer part.
Apr 10, 2009 | 2006 Kia Sorento
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
683 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
