Question about Water Heaters
Water starts out hot,after a couple of minutes it goes cold.
The first time it went cold the display was flashing ''C4 76''.I pressed the power button and it went off.I pressed the power button again and it came back normal.The next time and every time after that when it went cold the display read ''C7 76''.The time it takes to go cold is getting shorter,now to short to take a fast shower! I took it apart and gave it a good cleaning after the second time it happend,but it didn't make any differance.I cant seem to find any physical or electrical reason for its trouble. I would appreceate any help you can give me.
  • 117 Answers
Check the connections between the controller. try disconnecting it to see if that makes a difference. 76 means that it's either the PVC board of the connection between the controller and the tankless
Posted on Oct 03, 2009
Rinnai tankless water heater, modelRL94e
there must have been a power interruption during fill or while there was a flow (Water will not flow when power returns)
1. Turn of all hot water fixtures. Next press the ON/OFF button on the temperature controller twice. Will reset the fault.
Hope this does it. Let me know please.
Happy New Year!
Jan 01, 2018 | Rinnai Water Heaters
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Rheem warrior 40 gal warrior
You could start by seeing if the thermostat is wide open. Sounds like it is on low or vacay mode. How far is the run between your heater and the bathing area. Might need to insualet some piping.
Sep 24, 2013 | Water Heaters
Eternal water heater sa 06 code
What does it mean when the Eternal tankless water heater reads a SA.06 code when you press "diagnosis" button on the front???? We only get about a minute of hot water and then it goes cold. Customer service 24/7 phone # 1-866-946-1096 is OUT OF SERVICE!!!
May 19, 2012 | Water Heaters
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
Jul 16, 2009 | Rheem Tankless Hot Water Heater...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Honeywell water heater. It's about 2 1/2 years old. I went to press the red button because the water was cold and it never got hot. The pilot is completely off and it won't go on after I press the red...
turn the gas valve button to piliot position, push it down and hold it, click the ignitor to light it... look thru the site glass to see the spark all at the same time, if it lights hold the button on the gas valve down for 30 seconds, let it up if it doesn't stay lit you need either a thermo coupling or a gas valve thermo coupling would be the first choice, the is also a filter around the bottom of th tank near the floor it needs to be clean that is the only soirce of air to run the heater
Apr 21, 2009 | Water Heaters
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Water Heaters Logo
349 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
