Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum shuts off after about 10 to 15 minutes
After resting for about 5 or 10 minutes it will go again for about 15 minuutes. I have cleaned it , doesn't help
  • 867 Answers
There is a moving part, like a bearing that seizes up when warm. may be the motor bearing, unit will have to be taken apart and inspected
Posted on Sep 27, 2009
Vacuum runs for 5 minutes ,then shuts down. Will restart after 15 minutes, then does same thing.
sounds like a built in feature. It is overheating, bad wire or circuit possible
Jan 01, 2015 | Vacuums
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
Why does my DC17 Animal vacuum keep shutting off?
Hi Emmeline,
I'm sorry to hear you're having difficulties with your DC17. From what you've described, it sounds as if the thermal cutout feature is shutting the machine down to prevent overheating. If you've already tried washing the filter and are still experiencing the issue, I'd encourage you stop using the cleaner and to contact us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The vacuum cleaner works for a few minutes then shuts off.After a few minutes it will start again,but soon shuts off again.
There may be as many as three air filters in the vacuum. Remove and thoroughly clean all of them and try again.
Gary
Apr 18, 2011 | Hoover Vacuums
After from ten to fifteen minutes of use it automatically shuts down but will sstart up again after fifteen minutes.
It sounds as if the motor has overheated at some point and damaged the thermal protector in the motor. Be sure all the filters are clean before operating the vacuum. If it continues to shut down, the thermal protector will need to be replaced. ( Part # 28382093 ) This is a very common problem with bagless vacuums, if the main filter is not cleaned after every vacuuming.
Mar 07, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
We have a dyson root cyclone and it shuts off after a about 5 minutes of running. Then after about 10 minutes it will run again.
Your description is typical of a machine that's overheating. This is almost always caused by a blockage, as restricted airflow can't keep the motor cool and the automatic cut-out shuts the machine off. It re-sets itself when it's cooled a bit. Check your operator manual for how to clear blockages, and also check that your filters are clean.
Nov 28, 2009 | Vacuums
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
98 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
