Question about Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire One Netbook goes to a black screen with white writing that says operating system not found when I try to boot it
  • 1 more comment
  • Belinda Darrell Sep 27, 2009
    No did not drop Acer Aspire One Netbook. It is only two weeks old
    The software that was installed was Norton Antivirus and Software from Nero
    I did try to reboot the netbook myself. However it says system failed, cannot find operating system
    Do I need a new program to boot the system?
  • 555 Answers
Sorry to hear that you are having issues with your Acer Aspire One.
This is often caused when the computer can't find the OS from the hard disk or any other drive. There are several causes:
- Bad hard drive.
- Bad CMOS/SETUP configuration.
- Damaged OS.
- Boot sector/MBR Viruses.
First, I need some information to determine what went wrong:
1. How old is the computer?
2. What happen before you got this error? (Installed software? dropped? Kids playing with it?)
3. Did you have this issue before?
4. Do you have the original discs and user manual?
Posted on Sep 27, 2009
  • Jose Pino Sep 27, 2009
    If you don't feel confident on any step, I recommend you to follow the last step.
    1. In that case, Using the user manual you should be able to access the CMOS/SETUP to determine if the hard drive is correctly configured. It should be indicated as AUTO DETECT. If everything looks ok, then,
    2, You need to reload the OS as indicated in the user manual. You should have the original CDs with drivers. If you are not able to install the OS,
    3. I highly recommend you to contact the store for assistance (perhaps replacement), or the manufacturer.
    Your computer shouldn't fail if it is only two weeks old.
My aspire one netbook says missing operating system what do i do
On my Dell Insprion Windows 7, I have got "Missing Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
Apr 01, 2012 | Acer Aspire One D257 Netbook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
Hi my acer aspire 1 a0531h won't boot up!!!! when i switch it displays the acer logo then goes to a black screen with a white flashing cursor in the top left hand corner... i have no boot up disc as...
when the Acer logo comes up, press Delete (if not delete check the text at the bottom of the screen for the button corresponding to setup) and set the hard disk drive as the primary boot device
if the Hard Drive is set to primary (or referred to as 1st boot device) just leave the laptop at the blinking white curser.. it may just take a while to load if new hardware is found.
Mar 05, 2011 | Acer Computers & Internet
My screen is black with white writing, says operating system not found
Hello.
Usually that error means that there is a problem with your Windows operating system or your hard drive is faulty.
First, try to access the recovery partition. Boot your computer and press the Alt and F10 keys together repeatedly. Choose and go through the recovery process. If it works, your operating system will be OK, but everything you installed and saved will be gone.
If no recovery, then reinstall the operating system with a Windows CD. If no CD or problems, occur, then your hard drive is probably faulty and needs to be replaced.
Hope this helps.
Dec 26, 2010 | Acer Aspire 3634WLMi Notebook
My acer aspire one d255 goes to a black screen when powered on after you select run windows normally or safe mode. it is a black screen with a mouse pointer and that is it?
Go to task manager and try killing explorer.exe and try restarting the same
Take the system to safemode and do a clean boot
try removing unwanted startup items
Dec 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hi, my acer aspire one contracted a virus, then I turned it off, now when I turn it on it sticks on the acer logo page. Pushing keys does nothing. It just initially brings up a black screen with white...
i think there is problem with your system file of your windows.we need to repair your windows.
what you can do is use cd of your operating system that is windows,put it in cd rom and change the boot priority device to cd as first option from bios and boot from cd,once it is booted from cd,use the repair option and your system will start working
Oct 18, 2010 | Acer Computers & Internet
Netbook will not boot up ,keep getting blue screen saying could not boot up then goes back onto normal boot screen then goes onto black screen asking whether to boot up normally or in safe mode
you have a corrupted operating system, please restore the laptop by pressing Alt+F10 immediately after pressing the power button and follow the screen.
Hope this helps
Apr 06, 2010 | Acer Aspire One PC Notebook
Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
