Question about Kenmore 22622 Top Load Washer
Washer won't spin
My ge washer will not spin with almost any amount of clothes in it. i hold the lid switch down to help it start spinning with almost no clothes inside. it seems the last time i did this , i pulled upwards on the agitator it seemed to want to spin on its own
  • Kenmore Master
  • 5,569 Answers
You may not have received any response because you have used Kenmore 22622 category instead of posting with GE and the GE model #.
Regardless - you might remove the back panel of the machine and with adequate light peer inside and look for a belt. If your machine is belt driven, it may need a replacement if it has stretched beyond the limits imposed by any tensioner.
Posted on Jan 05, 2009
Washer not spinning properly
This should be belt driven? I would imagine jut adjusting the tensionwould work.
Dec 02, 2013 | Roper RAS8445KQ Top Load Washer
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
Won't spin
If a washer will agitate and wont spin check the lid switch. Lid switches are designed to not allow spin on most washer but will allow agitate. Safety feature.
If you need further assistance please feel free to comment me back.
Jul 27, 2011 | GE WBSR3140DW Top Load Washer
Machine won't spin out the water in the clothes,has to be wrung by hand..What would you think the part is that's holding this up?
Check the washer lid safety switch . Sounds like it is a simple switch for when you close the lid it allows to spin only when lid is closed. It is a safety switch for spinning to not operated if lid is open durring spinning cycle. It's maybe a 20 dollar part and easy install.
May 07, 2011 | Washing Machines
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
GE Top Loader Washer, spin cycle not working.
When you close the cover, there is a pin push the switch down, check that one, see if it is help.
Jun 02, 2008 | GE WBSR3140DW Top Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
Spin cycle doens't work
Your hand probably won't depress the lid switch far enough to actuate it. Use a pencil, pen or old toothbrush handle to press the switch down and see if spin starts. If it starts, the lid actuator is likely broken or out of alignment.
Apr 09, 2007 | GE WBSR3140DW Top Load Washer
Kenmore 22622 Top Load Washer Logo
166 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
