Question about Epson DFX-9000 Dot Matrix Printer
Printing two documents on the same page
Set up through windows then unix then in a financial application. Financial journals are being printed, two on one page instead of one on each page
How Much Time Does It Take For The Financial Institution To Sanction The Loan?
It could take between 5-20 business days after receipt of complete application and documents, with respect to the product, the loan profile, documentation requirement and lender. Typically, unsecured business loan may be the quickest whereas other kinds of loans take more time because of the security documentation.
Oct 20, 2015 | The Computers & Internet
I have just purchased and installed a J3600 Officejet printer. How do I get it to orient the print for a #10 envelope, which has to be fed in lengthwise?
You'll have to choose "#10 Envelope" as your paper size in whatever program you are printing from.
Then pick "Landscape" in the print options menu when you go to print on the envelope.
Apr 15, 2008 | Office Equipment & Supplies
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
What is ledger
A ledger contains summarized financial information that is classified by assignment to a specific account number using a Chart of Accounts. A ledger can be a physical book or also refer to software or spreadsheets where the financial information is recorded.
A General Ledger contains a summary of all the information recorded in subsidiary ledgers, which are ledgers that break down and show more information according to classifications.
Financial information for ledgers is taken from the company's journal.
Jul 11, 2011 | Super Tutor Trigonometry (ESDTRIG) for PC
Had to change to vista and program will not work need to print an amortization as I only have first page and lost the follow up pages on loan
Windows Vista or Windows 7, will have problems running some older versions of applications, just because so much has changed under the hood from Windows XP days. Thankfully there is a compatibility mode that can be easily set per application.
Read the steps on how to ,on this link:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 02, 2011 | Global Star Software Financial Tools...
I would like to find a good business apps but I sure don't want to pay for it. Do you know any free business apps?
Here are some good finance apps you may use for free: 1. PageOnce -PageOnce is a useful site that allows you to view many different accounts on one page. This can range from social sites like Facebook to email accounts. However, the real use for PageOnce from a business perspective is the ability to add financial services accounts to the page. It supports more than 6,000 financial services- including credit card accounts, bank accounts, and investment accounts. 2. iProcrastinate Mobile-There are plenty of to-do lists and project management applications for the iPhone, but most of the best ones cost money. Not so with iProcrastinate Mobile. This terrific application gives you a slew of features without being overbearing or difficult to use 3. Box.net - Accessing your spreadsheets, presentations, and other documents while you are on the move can be very useful. Box.net provides an convenient way to access, share, and collaborate on your business documents.
Sep 06, 2010 | iPhone Apps
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
HOW TO POST PAST YEAR ENTRIES INTO MYOB
You would have to post the entry as last financial year, just to keep it all ligit. After you have done so check that your retained years earnings are correct!.
Jun 30, 2009 | Myob Accounting Plus (BPJUBC00) for PC,...
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Epson DFX-9000 Dot Matrix Printer Logo
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
