Question about Protron PLTV-32 Television
My protron pltv3250 stopped working - Protron PLTV-32 Television
  • 4 Answers
The power supply in the pltv3250 is a known bad problem, and thankfully replacements are easy to find on ebay or other internet sellers. Symptoms are usually a red light or no power light and completely unresponsive to the touch panel or a remote. I was able to find one at Power-On.com for $59.00 plus shipping, far cheaper than others on ebay. Their part code is lcd 194-3f (194W LCD power supply). It takes approximately 30 minutes to replace, from removal of the base to re-installation of the base.
Posted on Jul 29, 2010
  • 5 Answers
SOURCE: Protron pltv3250 32 in. lcd, no power, no lights
You will have to have the set checked by someone to confirm this,
but most likely there is a problem with the TVs internal power supply.
Posted on Jan 25, 2009
  • 267 Answers
SOURCE: need a service manual for protron pltv3250
unfortunaly most of the off brands do not have any type of support.
i might suggest to go to www.shopjimmy.com or googlr your make and model.. somtimes you find boards being sold that were taken out of sets with broken panels but the boards worked.
Posted on Apr 24, 2009
rulds2008
  • 3866 Answers
SOURCE: tv just went dead there is power at the outlet
I always tell my clients to check the PSU " power supply unit" there is a fuse on most of these check to see if its blown if it is then you will need to do the folllowing remove the fuse and take it down to a radioshack or a DYI repair shop and get the EXACT same fuse if you do not you can risk a whole lot more problem, i also tell my clients to have a qualified repair person look it it some will give you a free quatation before work is done. Due to the sitaution you are having there is not quick FIXYA on this but we do encourge you Vote FIXYA if you find that this information is of any help to you! I Thank You for you FREE question today and again Rate Fixya if it helps...
Posted on Apr 27, 2009
  • 2318 Answers
SOURCE: ME PUEDEN INFORMAR DONDE COMSEGUIR LA PC POWER
Hola German60,
Los diagramas para estas fuentes de alimentacion no se encuentran pero si un sitio donde puedes comprar la fuente completa.
Visita este enlace para que encuentres la parte para reparar tu LCD.
Suerte.
Posted on Aug 13, 2010
SOURCE: protron hdmi pltv3250 32 lcd tv does not turn on
Hey bro, I seen online a buncha people keep saying its a power supply thing that you wont find cheap online.
Do this for me:
1 Lay the TV on its face on a table with towels layed down.
2 Unscrew all the screws you can find.
3 When you take the back off you will fine a plug still plugged into the backing so unplug that.
4 Now you will see metal covers covering the guts or what have you. You wanna take the cover off the one on the left it should be the smaller of the two covers like 6in by 5 in.
5 Now look at the capacitors, some are covered up by these metal brackets. Remove the smaller of the 2 brackets to see all of em.
6 Ok back to the capacitors, if you're unsure of what capacitors are, they are cylinder in shape and standing straight up n down, theres black ones, purple ones and like a green one sittin there.
7 Notice how some of these capacitors are not flat on the top, they kinda look rounded?
8 Unplug everything plugged into the chip board and take it to radio shack and get the capacitors you need along with a soldering iron, or you can write down how many uf's and voltages they are and just bring your paper there.
9 You really should get the right uF its probably (1) 820uF 35v (2) 680uF 25v (1) 220uF 25v and (1) 220uF 10v.
10 Crappy thing bout Radio Shack is its hard to find some of em that have the same uF and Voltage. I know you can get a higher voltage but not sure of the uF.
11 If you do get the right parts which should be around 10 bucks or less, try your luck de-soldering the bad ones and pushin these new ones thru. Its not a hard job at all.
12 Do me a favor go to youtube and type in Polaroid tv repair and the guy fixes his tv the same way except he's only got a couple bad caps. It gives you a perfect example of how to do it.
Lemme know how you make out. If it dont work, lemme know what happens. My Email is FlareSideMuzik@gmail.com
Posted on Oct 29, 2010
PLTV3250 32 in. LCD Television: how much is a power supply for the pltv3250...
From $60 and up.
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, coomon problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
May 17, 2010 | Protron PLTV3250 32 in. LCD Television
Changed batteries and remote stiil not working
The Original Remote has been Discontinued for this Model.
If you wish to Buy a Substitute, you could buy it from ;-
http://remotes.com/store/protron/pltv3250.html
If you Want Original, you could Buy a Used One from :-
http://cgi.ebay.com/PROTRON-SPECTRONIQ-PLTV-3250-PLTV3250-TV-REMOTE-CONTROL-/220578781622?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335b8519b6
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 03, 2010 | Protron PLTV3250 32 in. LCD Television
What is the remote code number? my remote is not working and I am trying to program a universal remote, but can't find a code (protron pltv3250)
If your universal remote has a code search function (most do) you may have to try that. Allot of off brand tv's are manufactured by other companies. Check the back of the TV to see if there is a label that says "manufactured for Protron by ..." If a code search doesn't work post back with the brand of remote and we can try help you further.
Dec 30, 2009 | Protron PLTV3250 32 in. LCD Television
My Protron PLTV3250 32 in tv just turned itself off..wont turn back on
Your power supply is dead. You can get one from POWER-ON.COM for about $64.00 including shipping and handling. My 32 inch went dead after only one year and I just got a new power supply and it works fine.
Oct 18, 2009 | Protron PLTV3250 32 in. LCD Television
My protron tv stop working it seems like it is not getting any po
MOST OF THESE SET END UP WITH POWER SUPPLY PROBLEMS. MULTIPLE CAPACITOR GO BAD. EST. $200.00 ON UP.
Feb 06, 2009 | Protron PLTV3250 32 in. LCD Television
Jan 24, 2009 | Protron PLTV3250 32 in. LCD Television
Can only turn tv on manually
what kind of universal remote did you use? I am having the same problem. I use my dvd/vcr remote but i have to get up to adjust the volume.
Jun 15, 2008 | Protron PLTV3250 32 in. LCD Television
Isn't this a Protron PLTV3250 page?
The shop that diagnosed your problem told you that to get you out the door without having to look like idiots and say ...."I dunno whats wrong with it". Shop by model # at www.shopjimmy.com. They have used circuits and modules for most brands. I'd start with the power supply, as it will likely be your problem.
Feb 05, 2008 | Protron PLTV3250 32 in. LCD Television
Protron PLTV-32 Television Logo
91 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
