Question about Kodak EASYSHARE 5100 All-In-One Printer
I changed the ink cartridges printed properly once now no black. printer says ink is full but fuzzy and no black?
  • 101 Answers
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} a. On your computer, open your Kodak AiO Home Center software.
b. Click on the Help (?) button.
c. Click on the Maintenance option.
Click on the Clean Printhead option
3.Print Demo Page.
Press Photo and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Posted on Sep 28, 2009
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Lexmark X4650 InkJet Printer black prints fuzzy. Color is fine, but the black appears out of focus.
Try to check and make sure your black ink level is still good and not about to go empty. On the printer operator panel, press the Setup button > Maintenance > Ink Levels.
If the black ink level is still good, make sure the cartridges are aligned. Try this approach. On the printer operator panel, press the Setup button > Maintenance > Align Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them as well as align the cartridges.
Try to print a document again to verify that the print quality has improved.
Oct 11, 2011 | Lexmark X4650 InkJet Printer
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Fuzzy ink
probably dirty or broken print head. suggest you replace it or get new blue cartridge if your machine has seperate colour cartridges.
Jun 17, 2009 | Brother MFC-5440CN All-In-One InkJet...
Print quality is terrible
Your printhead is in need of a cleaning cycle...
The black part of the K/Y printhead is pigmented and they tend to clog much quicker than the other dyebase colours. As a result you should run a cleaning cycle from the control panel
  • Setup button
  • Tools option (6)
  • Clean Printhead (option 3)
That will then run a printhead cleaning routine which hopefully will resolve the issue.
Unfortunately as I said the K/Y printheads are poorly built and you may need to replace it if, after 3 cleaning routines the output doesn't improve.
One solution is to switch to a Non-HP black cartridge that uses dyebase ink instead of HP's pigment but that's only if you get this more than once.
Hope that helps.
Feb 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
Out off ink
When you say the 'ink has been changed do you mean colour or black only. It does not matter what you are trying to print the printer must have a full set to function, If you have a full set remove the cartridge[s]. Switch off the printer wait 30 seconds switch on put the cartridge carrier to its proper position and reload the carts Further info from www.fixyourownprinter.com
Jul 03, 2007 | HP OfficeJet d145 InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
90 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
