Question about Saeco Starbucks Sirena Espresso Machine
Cannot Prime Starbucks Sirena
Have same problem as others. In order to prime the Starbucks Sirena machine, I turn the power sitch on, then turn steamer knob on. The pump runs only for about ten seconds and stops - water does not come out. Until I can prime it, I cannot use it. Tried multiple times. Any solutions? Did not work to put downward prssure on water tank - as suggested in earlier thread.
In regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Posted on Nov 29, 2009
  • johnshami Nov 29, 2009
    the word **** means pulling air out of tube tip by your lips sealing tube tip an inhaling through your mouth
  • 4 Answers
I tried the inhale method sip method described but, i could not get enough vacuum, but it got me thinking in the right direction.
You do not need to disassemble this machine, it will not heat unless it is prim
WARNING: machine must be STONE COLD before attempting this!
1. Get a large syringe (Without a needle of course, I used a 60ml one I bought at a pharmacy for $3.)
2. Fill the water tank full
3. Pull off chrome tip on the steam wand to expose the black plastic jet where steam comes out.
4. Place the tip of the syringe onto the tip of the black plastic steam jet on the machine.
5. Push the power button ON.
6. Turn the steam knob clockwise all the way until the pump starts.
7. Press the syringe onto the jet firmly to seal the connection, and simultaneously draw the plunger out.
8. Quickly, release the seal and eject the air in the syringe out (into open air not into the machine)
9. Repeat steps 7&8 until water draws into the syringe.
10. Go make yourself a cup of coffee and celebrate that you overcame the flaw in this machines design that renders most of them to the rubbish heap.
Posted on Jul 04, 2017
I had the same issue also. The way I solved it was to lift very slightly on the tank. Or what you can do is just remove the tank and set it in very very lightly. The light turned off and I heard the machine click. I was able to use my free hand to turn the pump on and prime it and water actually came out.
Only problem is that I had to keep the tank slightly higher than it wanted sit for it to work at all. I had to use some rubber band around the little legs on the back of the tank so it would sit higher, and it sits on the sensor correctly. If it doesn't it will have a steady blue water light . I know... it is ghetto, but saves you from shipping to the manufacturer. hope this helps. Sad that this machine cost so much, but it is so touchy that if a squirrel in your back yard farts it stops working.
Sirena Espresso Machine powers on but will not heat up and water not priming
After weeks of trial and error, I have found the solution, to prime the Starbucks Sirena Saeco Espresso Machine (woohoo!!!!!!!!!! ). You do not need to disassemble this machine, it will not heat unless it is prim WARNING: machine must be STONE COLD before attempting this! 1. Get a large syringe (Without a needle of course, I used a 60ml one I bought at a pharmacy for $3.) 2. Fill the water tank full 3. Pull off chrome tip on the steam wand to expose the black plastic jet where steam comes out. 4. Place the tip of the syringe onto the tip of the black plastic steam jet on the machine. 5. Push the power button ON. 6. Turn the steam knob clockwise all the way until the pump starts. 7. Press the syringe onto the jet firmly to seal the connection, and simultaneously draw the plunger out. 8. Quickly, release the seal and eject the air in the syringe out (into open air not into the machine) 9. Repeat steps 7&8 until water draws into the syringe. 10. Go make yourself a cup of coffee and celebrate that you overcame the flaw in this machines design that renders most of them to the rubbish heap.
Jul 12, 2015 | Saeco Starbucks Sirena Espresso Machine
My sirena has blue blinking water light even though it has a full amount of water
Turn on the machine and turn the steam knob all the way on. Let it run until the light goes off. This primes the pump. It should run properly after that.
Oct 01, 2011 | Saeco Starbucks Sirena Espresso Machine
Starbucks Sirena espresso flashing blue light & does not heat up
Gary,
I have the same exact problem with mine starting today, did you get this figured out? I'd love to know if it's fixable or not as I was planning on selling my previous machine. If it's an expensive repair, I'll just have to ditch this one and go back to my previous one.
Jan 04, 2010 | Saeco Starbucks Sirena Espresso Machine
Unable to prime Sirena Espresso Machine
Nov 28, 2009 | Saeco Starbucks Sirena Espresso Machine
When i turn it on all the lights do is blink it never heats up pr any thing all the lights just blink
we had this problem on the same machine. This was in the manual and solved the problem- prime the machine using the steam wand. Turn it on and let it flow until the blue light goes off.
Nov 13, 2009 | Saeco Starbucks Sirena Espresso Machine
The machine lights don't turn on
sounds like you need to prime the machine. check the manual for those instructions. if (like us) nothing happens, then read on:
johnshami had this solution on another post, and it worked for us when the manual's instructions to "prime" the machine resulted in no water leaving the tank to enter the machine:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
Starbucks Sirena. lights blink, won't heat.
johnshami had this solution on another post, and it worked for us:
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
866 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
