Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
The motor will only run at 3/4 choke
I have cleaned the carb but it still will not run without choke on.
  • 20 Answers
You cleaned the carb, but did you replace the carb neck to intake gasket? If so,tune the carb, set the float, check the air cleaner, replace the fuel filter. Replace the fuel. Replace the jets.
It sounds like you are lacking fuel, or have excessive air.
Any one of these things, or a combination of any will help.
Posted on Oct 02, 2009
Echo GT225 has new carb.but will not run without 3/4 choke lines clean spark arrester cleaned, new plug, good compression ,tank vent replaced ? stumped
New carb is supposed to run fine with no choke at all. But I have 2 instances where the new carb would run for sh-- unless I left choke setting at mid point. Went crazy cleaning out new carb, resetting idle and low and high mixture screws to no avail. But both were running great and and gas consumption was fine with that choke setting. Left well enough alone. both start and run great. You might want to do same.
Sep 06, 2017 | Echo Garden
Motor sat for eight yrs, cleaned carbs, motor will start but dies out , motor will run with choke almost closed, whats the solution ?
I do not have any information on what type, size or year engine you are referring to. Generally speaking it sounds like a clog is still present in the carb. Check the Main jet and the orifice leading to the small brass tube in the center of the carburetor venturi. Or it could be the idle circuit which is a pin hole or two behind the throttle plate. When you close the choke ( I'm assuming the engine has a choke plate not a primer) it will pull fuel out of the float bowl and feed the engine. So fuel is not going through the normal channels.
Your carb need to be taken apart and have all circuits cleaned and the float needle and seat cleaned (replaced) and float level set to level. Make sure you can blow compressed air through all the circuits. You can also get a welding tip cleaning kit to poke out the circuits. It most likely has "varnish" in the bottom of the float bowl still preventing enough fuel from getting to the ide circuit or the venture without assistance from the choke
Nov 13, 2015 | Boating
When I move the choke to run the motor dies....even after 30 minutes of running.
No, but it sounds if the carb needs to be cleaned! Fresh fuel helps too. Check the spark plug and check the breather filter. Also you can crank the engine with the breather filter off and try to move the choke to run then. If it runs with the filter off then there is your problem! 1 question, has anyone try to work on it or adjust the carb in any way?
Sep 25, 2014 | Honda Pressure Washer PSI 3000
Carb was sludged up, took it apart to clean, now motor starts and runs, but won't run without choke
pull out the idle air screw blow out w/ carb cleaner & make sure slow jet is clear..try harleytalking.com they have helped me ';';';
May 01, 2011 | Harley Davidson XL 1200 C Sportster Custom...
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My chainsaw Model 142 - motor runs wide open with choke at 1/2 choke - will notrun otherwise
either fuel is restricted or air is leaking into motor inspect fuel lines fuel filter check for carb tightness or pull carb and clean. replace carb parts with kit
May 20, 2010 | Garden
Won't idle without choke, turn throttle boggs out
have u checked the float hight on the carburator? also make sure ur choke curcuit i clean and free of dirt
Apr 13, 2010 | 2005 kawasaki KLX 125
15 horse mercury outboard
Clogged jets in the carb...clean out carb or rebuild carb.
Jul 28, 2009 | Boating
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Not getting enough gas to the carb have to run choke 3/4 engaged
Sounds like a restriction in your carb, not getting enough gas. I would clean out the carb again.
May 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
787 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
