Question about Philips GoGear HDD6330 MP3 Player
Remove rear cover of HDD6330
I've been trying to remove the rear cover on a HDD6330, and have onlybeen able to disconnect the tangs on the side with the on/off switch. I can't wedge anything between the section with the tangs on the otherside (volume up/down). Does anyone have any tricks on this?
  • kerbitz Dec 18, 2007
    nevermind... a little persistance and I was able to remove the cover. Did a little damage to the case though. Does anyone have a special tool they use to remove the rear cover?
  • 476 Answers
You need to make sure the two black screws either side of the connector have been taken out.
The back panel has clips on both sides.
Volume side - 1 at the bottom, and 1 next to the volume control
Opposite side - 1 at the top and 1 at the bottom.
Try sliding a metal strip ( about 5mm wide) in at these points.
If the strip doesn't slide in, gently lever the casing apart at the corner with a flat blade screwdriver.
Posted on Feb 08, 2008
Where is the inline fuel filter located on a 2001 Holden astra
Hi Walter going from memory there are two possibilities.
1 right hand side just in front of rear wheel up under car .(may have steel or plastic cover over filter). RHD drivers side.
2 rear of engine on fire wall.
please note make sure engine has not been running for a few hours wear safety glasses (a must). There will be some pressure there so cover with rag at parts where you disconnect. to release the clips you need to push the pipes towards the filter. There is a special tool available to push the clips in which is guaranteed not to damage the clip for reinstallation. However personally I have rarely used it, I have always used a small flat edged screw driver WITH CARE!! If you study the clip there are two tangs which need to be pressed in which you can do one side at a time just slightly lean the plastic pipe to one side on the tang you release (away from filter).Then release the second tang slowly release the pipe off the filter now is the time to cover with rag. The tangs are in the square cut out windows.
Good luck
Jul 20, 2018 | Holden Cars & Trucks
How to remove rear fender on 2004 FXDL
Hi Anonymous, start by removing the seat and disconnecting the battery ground cable, then disconect the the tail lite and turn signal harness at the connector blocks. note you may have to remove some wires out of the blocks, to facilitate fender removal, by depressing the tangs with a small screw driver and a razor blade to pull them back for installation. Turn signal wires will be one of these. Remove fender strut covers, turn signal assemblies will remain on covers. There is a bolt on the inside of the fender up front in the middle also a couple on the sides that go through the struts. Depending on your patience, small hands, skinny fingers, and 1/4 drive flex sockets and extention collection you might be able to perform this delicate operation with out removing the rear wheel, otherwise by blocking up the bike with wood so rear wheel is about 6" off the ground you can remove the lower shock bolts and let the swing arm and wheel gently down to gain easier access to the inside of the fender bolts.Be patient, be carefull, and use common sence is case I forgot something. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 14, 2014 | 2003 Harley Davidson FXDL Dyna Low Rider
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
Head lamp replacement on a cadilic catera
  1. Open the hood.
  2. Unscrew the self-locking tab on the left side radiator cover.
  3. Unclip the left side radiator cover from the body to remove the left side radiator cover.
  4. Remove the battery.
  5. Remove the rubber protective cover from the back of the headlamp to reveal the bulb.
  1. Separate the bulb fastening tangs (1).
  2. Carefully remove the bulb.
  3. Remove the electrical connection from the bulb.
INSTALLATION PROCEDURE:
  1. Install the electrical connection to the bulb.
  2. Snap the fastening tang (1) in place to install the bulb.
  3. Install the rubber protective cover to the back of the headlamp.
  4. Install the battery.
  5. Seat the tab to the body of the left side radiator cover.
  6. Secure the left side radiator cover by turning the self-locking tab.
  7. Close the hood.
  8. Reprogram the applicable accessories. this is for a 1998 what year is yours if its newer its a different procedure tell me if it is
Dec 24, 2010 | Cadillac Catera Cars & Trucks
Do I remove the entire cover or the little door thats atached to this cover on the passenger side? There are 3 brake lights that were recommended to replace. Driver side and passenger side plus the third...
Lamp, Rear Hi-Mount Lamp Assembly
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Raise the liftgate.
  1. Remove the liftgate door trim panel (46404) . Refer to Section 01-05 for the removal procedure.
Trim Panel, Liftgate Door Removal
  1. Disconnect thebattery ground cable (14301) .
  1. On vehicles with a rear window wiper, remove the three rear wiper motor cover screws and remove the rear wiper motor cover.
  1. Pry the liftgate door trim panel (46404) away from the liftgate.
  1. Disconnect the luggage compartment lamp electrical connector.
  1. Rotate the rear hi-mount lamp socket counterclockwise and remove it from the rear hi-mount lamp (13A613) .
  1. Remove the two rear hi-mount lamp housing nuts and remove the rear hi-mount lamp lens and housing.
Oct 18, 2010 | 1995 Ford Aspire
I have to change the heater blower moter switch how do I do that
SECTION 412-02: Heating and Ventilation 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 10/6/2003 Blower Motor Removal
All vehicles
  1. Remove the footwell lower trim panel.
  1. Open the glove compartment.
  1. Remove the footwell vent air duct.
    • Pull off the hose.
  1. Close the glove compartment.
Vehicles with electronic automatic temperature control (EATC) built 11/2003 onwards
  1. Disconnect the blower motor control module electrical connector.
All vehicles
  1. Disconnect the blower motor electrical connector.
  1. Remove the blower motor.
Installation
NOTE: Procedure if there is a concern over whistling noises from the heating system.
  1. NOTE: Set the air distribution switch to ""Head area” and the temperature control switch to ""MAX cooling”.
    Remove the ventilation center nozzle and open the glove compartment.
  1. Unclip the passenger side defrost nozzle air duct and position it on the open glove compartment cover.
  1. NOTE: Do not allow any parts of the joining tang to pass behind the instrument panel.
    Remove the two-part plastic joining tang on the heater housing.
    • Cut the joining tang at the top end using side cutters, break it off at the bottom and discard it.
  1. Cut the sealing tape into a 50x50 mm square.
  1. ani_caut.gif WARNING: Sharp edges on the heater housing.
    Feel for the gap in the heater housing, affix the sealing tape over the gap from the inside and press it firmly in place.
    1. NOTE: Apply the sealing tape in the position shown. The sealing tape must not be applied higher than the position shown in the illustration.
      Heater housing (shown in cross section)
    1. Sealing tape
  1. To install, reverse the removal procedure.
2010&c18=modelyear&c20=g18286&c35=wsm%2cblower%20motor%2csyy%2c412-02%2cremoval%20and%20installation&pid=wsm%2cclimate%20control%20system%2csyy%2c412-00%2cdescription%20and%20operation&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=29&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=491&ct=lan&hp=n&[aqe]
Apr 04, 2010 | 2000 Ford Focus
How to install fan in dell 2400 desktop computer
Rear computer case fan?
This is going to be a fairly long solution. Advising you in advance.
1) Computer off, and unplugged from power.
2) Open the computer case, TOUCH the metal frame BEFORE you reach inside. Your body carries Static electricity. Touching the metal case will relieve your body of Static.
3) Remove the Processor Air Shroud.
This is the plastic U shaped part that covers the Processor, and Heatsink. It's at the back of the computer next to the computer case, and the fan in the rear.
First, unplug the fan's power cable from the motherboard connector.
(J30 connector on motherboard.
In-between Ram slot 1, and the Processor)
Second, you may have to disconnect the power cable for the Processor, in order to remove the Air Shroud. Disconnect the Processor power cable from the motherboard.
(J10 connector. Square connector on the motherboard to the left of the Processor, and down. There is a power cable from the power supply that goes to it, with a square connector, and has four wires in the cable. Two Yellow, two Black wires)
You may have to disconnect the 20-pin ATX main power cable also, in order to have room to remove the Air Shroud.
(J21 connector on motherboard. Long connector with 20 socket holes in it. It's on the outside edge of the motherboard, to the right of the ram slots.
The power cable connector is a Male connector. The connector on the motherboard is a Female connector.
The Male connector has a lock tab on the side of it. The tab is hinged so that it pivots. The top of the tab is squeezed in to release the lock.
This action draws a hooked end of the tab, out of the Female connector on the motherboard. While keeping the tab squeezed, the Male connector is gently wiggled side to side, while pulling up, and out.
Do Not pull on the wires, pull on the Male connector only. Use a gentle force)
The Air Shroud is gently squeezed in on the sides, with your fingers, and thumb. (Side that is towards the Front of the computer)
Then the side of the Air Shroud that is towards the front of the computer, is lifted up.
The Air Shroud pivots towards the rear of the computer.
The Air Shroud pivots on two round pins. Pins are made into the plastic shroud itself.
Each side of the air shroud, is gently pried out on the bottom where the round pivot pin is, and this action draws the pin out of the rear fan's mounting flange.
Remove the Air Shroud, sit it aside.
Now you can look more closely as to how the fan's mounting flange is attached to the computer case.
At this point I cannot lead you directly, only guide you.
The fan's mounting flange, may have small flat protrusions coming out of it, that go through the rectangular ventilation holes, in the rear of the computer case.
The flat protrusions has a hooked end on them, that hooks on the edge of the ventilation hole. Usual style, requires that you push the hooked end, towards the inside.
(Reference is made in relation to the outside edge of the computer case. The hooked end is pushed towards the middle of the computer case)
It may be a style of mounting flange, where the flange's edge has a lock tang that sticks up.
This lock tang is part of the plastic mounting flange itself.
The lock tang is depressed towards the computer case, and the fan is slid up, and out of a metal bracket.
(May be more than one locking tang)
Observing the mounting flange for the fan, you should be able to see how the fan itself, is attached to the mounting flange.
Usually it's another form of locking tang that is used.
The locking tang, or tangs, are depressed, and the fan slides out of the mounting flange.
If you did not buy a replacement fan directly from Dell, (Don't even know if you can), observe the fan's power cable connector.
Observe where the wires go in the connector. Look at the color code of the insulation of the wires. Match this wire color code, to the original Dell computer case fan.
Are the wires in the same place as the Dell fan?
If not, tell me. Post in a comment.
Jan 24, 2010 | Dell Dimension 2400 PC Desktop
How hard is it to put in an ignition in a 89 ford probe gt turbo?
This is what it looks like to replace it....you decide on what your level of mechanical knowledge is. I hope this helps you!
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Remove the lower instrument cluster cover as follows:
    1. Remove the steering wheel. Refer to Section 8.
    2. Remove the 2 column cover screws and the cover.
    3. Remove the 9 cluster module mounting screws.
    4. Carefully pull the cluster module outward and disconnect the electrical connectors.
    5. Remove the ignition switch illumination bulb and remove the cluster module.
    6. Loosen the 2 cover hinge screws and the 6 upper cluster cover screws. Remove the cover.
    7. Remove the lower cluster cover panel.
  3. Remove the lap duct and the defrost duct.
  4. Remove the mounting nuts from the hinge bracket.
  5. Remove the steering column upper mounting bolts/nuts and allow the steering column to hang down.
  6. Remove the screw securing the ignition switch to the ignition switch housing.
  7. Disconnect the 4 ignition switch snap connectors located to the left of the steering column.
  8. Remove the protective looming from the ignition switch wires.
  9. Note the position of each wire in the 4-terminal connector for installation reference. Disconnect the 2 wires (green wire and red wire/orange tracer) of the key-in warning buzzer at the 4-terminal connector by disengaging the tang with a paperclip or other suitable tool.
To install:
  1. Connect the 2 wires of the key-in warning buzzer to the 4-terminal connector as follows:
    1. Align the flat side of the wire end with the grooved portion of the connector.
    2. Push the wire into the connector until the locking tang engages the end of the wire.
  2. Install the protective looming around the ignition switch wires.
  3. Connect the 4 snap electrical connectors of the ignition switch to their mating connectors, pushing together until the locking tangs are in place.
  4. Install the ignition switch into the switch housing and secure it with the screw.
  5. Raise the steering column into position. Install the upper bracket bolts and tighten to 12-17 ft. lbs. (16-23 Nm).
  6. Install the cluster support nuts and tighten to 6.5-10 ft. lbs. (8.8-14 Nm). Install the hinge bracket nuts and tighten to 12-17 ft. lbs. (16-23 Nm).
  7. Install the lap duct and defroster duct.
  8. Install the lower cluster cover panel and the cluster cover.
  9. Install the ignition switch illumination bulb. Connect the electrical connectors and install the cluster module with the attaching screws.
  10. Install the column cover and the steering wheel.
  11. Connect the negative battery cable and check ignition switch operation.
Ignition switch removal and installation—1989 Probe
Nov 19, 2009 | 1989 Ford Probe
HDD6330/17
Hi -- as you say the rear metal case needs to be removed, best start around earphone connection, use thumbnail or thin stif plastic,ease under metal case in and work across top, then bottom sections then onto the side (on/off)switch there are two plastic "tanges" about one third along then two thirds along that need to be pushed inwards and upwards.The other side again two "tangs" but both these two are in bottom half only, at quarter and half way position. Please be very careful and dont insert tool to far 2-3mm at very most.
Sep 21, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
55 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
