Question about Briggs & Stratton Garden
Gas in the oil,white smoke - Briggs & Stratton Garden
  • 80 Answers
You have A blown head gasket or a crack in the block somewhere.
John
Posted on Sep 28, 2009
White smoke from p1500 trimmer
Too much oil in the gas or water in the gas
Drain the gas, refill with fresh clean oil/gas mixture
Apr 03, 2016 | Poulan 25cc 2-Cycle Gas Powered String...
White smoke from BMW 740i exhaust
white were? the exhaust tip, or other spot, long pipe, name spot?
white, is steam or OIL.
oil smells like burnt oil and takes for ever to dispate
steam is water, and smells , sweet due to 50% glycol inside.
and goes away fast.
but all Gas engines make water at all the time running as a by product of combustion and for sure on cold days, some times full time cold
due to climate effects.
does your neighbors car smoke at same time, (look)
bingo , dew point.
all gas engine smoke cold started, (steam)
so first find out what it is,
take the dip stick out of a hot engine. stalled, drip it on the exhaust
see that smoke ,smell it? that is burning oil
now you know what you have, steam or oil. smoke.
Jan 18, 2014 | 2004 Suzuki Forenza
Oil leaking from air filter area of push mower and mower smoking
You have overfilled the oil tank. White smoke is only a hassle, not a serious problem. You have to empty some of the oil and change the gas. Clean the air filter if it is the spongy type with Dawn Dishwashing Liquid, rinsing and drying it well before reinstalling. The white smoke will stop soon as it is still in the gas that is in the carb. If the case is that you haven't filled it with oil prior to this smoke then you must be mowing on a hillside and the gas tank was on the lower side allowing oil to leak into the gas. Same solution.
Jun 24, 2009 | Poulan Garden
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Trying to diagnose an internal engine smoke problem, 06 prius was working fine, all of a asudden i hear the gas engine come on and it sounds like valve or rocker noise, very lightly, i go to check the oil...
White smoke coming out of the oil fill cap is not good, it means there's water in there (white smoke = water, blue smoke = oil, black smoke = lots of junk in gas or ruined engine). I suspect bad head gasket or cracked block.
Jun 14, 2009 | 2006 Toyota Prius
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We have not ran the car in a while a little white smoke
White smoke is a sign of a blown head gasket and coolant is getting into the engine with the oil and gas. Check your coolant for signs of oil, and smell for signs of gas. Check your oil and see if it is milky. Milky oil means that coolant is getting past the head gasket.
Dec 05, 2008 | 1988 Ford Thunderbird
Blowing white smoke
how much white smoke? white smoke usually indicates a headgasket
oil should not be black that quick
Sep 23, 2008 | 1998 Mitsubishi Eclipse
Garden Logo
138 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
