Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
My pressure washer starts pressure builds but it will not spray
Constant pressure
Some of these machines require you to hold the spray handle trigger in the open position while starting the motor, once it is running let the trigger go and it should run on bypass
Apr 11, 2014 | Craftsman 2500 PSI Briggs & Stratton...
I have a Husky power washer 2600 psi starts & runs until it seems to build Pressure and will not spray then motor boggs to a stall
Some models have a tiny orifice in the adjustable spray head.(if equipped) Which can become clogged by debris or calcium buildup. Water should flow through even when unit is off and sprayer handle(on/off) is operated if there is no water then you definitely have a clog.
Oct 31, 2013 | Garden
Wont spray
I hope the engine wont spray... if it's a pressure washer thats not spraying the name of the unit would help... but does it build pressure but doesn't spray - check the wand
does it even build pressure ??? no - replace pump
Oct 18, 2013 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
Generac 6hp pressure washer starts and runs fine, no real leaks, but it never builds up pressure.
after making the water connections, be sure to hold the trigger open on the wand for a couple of minutes before starting. All the air must be removed from the system before it can create pressure.
Aug 28, 2013 | Briggs & Stratton Pressure Washer...
Simpson 3100 psi washer will not spray
The pressure relief valve is sticking open.
May 15, 2013 | Garden
Hoda power washer low on pressure
Caused by either of two things: The pump is worn and needs to be rebuilt or replaced. OR the pressure relief valve ( protects the motor from excessive pressure build up when you turn spray off) , is stuck in the open position thereby not allowing pump to build up pressure .
Apr 04, 2013 | Honda Garden
Motor turns over but seems to be a lot of pressure on it . it kicks back hard
Make sure you are holding the trigger and water is spraying while you are trying to start it, otherwise pressure will build up in the pump and it will kick back.
Jun 06, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Builds up pressure won't spray
pressure relief valve is faulty. replace.
Aug 10, 2009 | Garden
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Apr 05, 2009 | Garden
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
110 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
