Question about Maytag Dryers
Dryer spins but dosen't get hot
The dryer spins but dosen't get hot, I've inspeted the igniter it's working
Since you indicated that it had an igniter I assume you have a natural gas or propane model. I had some trouble with a Hotpoint dryer and replaced the igniter. That didn't solve the problem. I then decided to just change the gas solenoid and the flame sensor at the same time and it worked fine again. I got them both cheap from Ebay from the same seller.
The flame sensor tells the machine if the ingiter was able to light the gas burner. If it doesn't sense the heat it will turn off the gas solenoid so your house doesn't fill with gas. The gas solenoid is an electrical valve that lets the gas flow into the burner. You should be able to hear the gas solenoid click when it opens and then your igniter will glow and start the flame. If it shuts itself off within a minute of that then I would suggest the flame sensor as a starting point. If it never clicks then I would start with the solenoid.
Good Luck and post back here if you solve it for the next person with your trouble.
-- Kevin
Posted on Sep 27, 2009
I have a 02 Pontiac Grand Prix... I've been having
lean motors run hot so check for air leaks including brake booster hose. check ignition timing for too far advanced . Check that the thermostat has the correct opening temp setting or is even the correct type for the vehicle. check that the bottom radiator hose dosen\'t suck in on revs restricting the water flow.It it\'s an auto check that the gears are operating correctly especially if there is an o/drive facility.Replace the lead giving you pain
Jan 09, 2013 | Cars & Trucks
No heat from dryer
If a Gas dryer look first to see if igniter is coming on or if drum where clothes are gets hot or not.
Dec 10, 2012 | Dryers
Heater dosen,t work
you might have a problem with your heater core ,also check your radiator and make sure it is full if you are low on water that will also cause cold air to blow or your actuator witch is a control switch that opens the vale to let hot water pass through giving you hot air good luck
Nov 30, 2011 | 1997 Chevrolet Lumina
I push start button and it humm's and dosen't spin i open the top of the dryer and then push the start button and the push the drum to jump spin it and then it work's.any thought's
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Dryers
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
Gas dryer spins but wont get hot
ok im confused here, is it an electric or gas dryer,if its gas its prob the igniter that is bad,
Oct 21, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
My kenmore 80 series dryer wont heat up how do i fix it
could be the igniter or thermal fuse if you hear the gas valve click open and there is no glow inspect the igniter for a hot spot or white spot where the brek occured,some dryer will spin but not heat up if the thermal fuse is blown
Mar 20, 2010 | Dryers
Whirlpool duet dryer doesnt get hot
Is this a GAS Dryer? Or, an ELECTRIC Dryer?
If this is an ELECTRIC dryer, the following link will give you some advice on how to troubleshoot a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If this is a GAS dryer, the most common failure for heat related problems in a gas dryer is a weak or blown igniter on the burner assembly.
The way the ignition system is supposed to work is like this:
1. Select the dryer cycle and press start.
2. The drum begins to spin and the igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 to 90 seconds from the time you start the dryer to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
You can purchase replacement parts (if required) at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance.
If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 27, 2010 | Dryers
Dryers Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
