Question about U-Line Icemaker
U-Line undercounter frost free ice maker refrigerator
Water freezes under ice bin. Where does it come from?
Has been serviced 4 times with different techs.
They clear out defrost water drain and/or replace drain heater. It is OK for about 3 months, then same problem. Ice maker runs until full bin and replaces what we use, so it is usually full. The older/lower ice is covered with 'frost'. The U-Line people say they have not had this problem from anyone else, but continue the warranty.
Any ideas?
Charles
  • Anonymous Mar 28, 2014
    alarm keeps going off will not make ice....i unscrew the lower drainage nut to drain, but nothing comes out
  • 833 Answers
All units made today have defrost timers to clear ice from the evaporator. Some of the ice sublimates...turns directly into humidity in the air in the box. It re-condenses in the ice tray area. It is possible that nothing is wrong other than excessive opening of the bin area or the defrost timer is running slow and staying on too long. You may also be consuming the ice too slowly. Can you either change the amount of ice in the bin by adding something to simulate part of the ice content or shut off ice production against low demand?
Posted on Dec 21, 2007
Why is water coming out under the refrigerator?
Maybe the freezer defrost drain is blocked. Sometimes the water freezes in the drain and the next time the defrost cycle occurs the water can't drain correctly. Is there any water inside the refrigerated section of the unit? Also there may be a catch pan under the fridge that is misaligned or out of place or the drain line isn't positioned to place the defrost water into the pan. Most modern refrigerators are frost free and defrost the freezer on a regular timed cycle. This is why your ice cubes shrink and stick together and why you get freezer burn on the food left in them for extended time.
Jan 25, 2015 | Maytag Refrigerators
Why isn't my U-Line 3018CLR making ice?
Isn't it obvious the compressor isn't running to freeze the water? Make sure the thermostat is working.
Jul 17, 2014 | ULINE U Line 3000 Series 3018CLRS41 20"...
The bucket that holds the ice is freezing all the ice together and then it will not come out of the dispenser
You have a bad water valve, this causes water not to stop entering the unit and causes one big cube. You didn't mention any ice or frost behind the ice bin so I will assume you have none. the water valve should correct this issue.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 16, 2013 | U-Line CO2075F-B Echelon Refrigerator Ice...
Refrigerator ice dispenser freezes up
Refrigerator ice makers can fail for several reasons, some simple and some tricky. First, look for kinks in the water supply line tubing. Carefully roll your fridge away from the wall to inspect the line and connections located behind it. Straighten any kinks. Note: Use caution when attempting to straighten the 1/4-inch soft copper tubing. It can easily break!
If your system includes a water filter, the filter may be clogged or installed incorrectly. Check your manual and replace as needed, or have a qualified professional do it for you.
Check the ejector arm (inside and under the bin) and the delivery chute (on the door, below the bin outlet) for blockage. Use a plastic utensil to clear them as needed.
For additional troubleshooting steps and solutions, see Ice maker not working. I hope this helps!
Sep 19, 2012 | Maytag MSD2454G Side by Side Refrigerator
Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
Jun 05, 2009 | U-Line Refrigerator Ice Maker
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
U-Line Icemaker Logo
266 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
