Question about Air Tools & Compressors
Is it possible to get a driver for a Tool Shop 18 gauge nailer?
    Problem Solver:
  • 13 Answers
Most likely but sometimes it depends on the brand
Posted on Oct 01, 2009
Dewalt 16 guage 18 volt finish nailer will not shoot nails
1) Check to see if the drive belt is intact
2) Check and make sure the driver blade is not bent
3) Make sure return device is properly clipped down so the driver can fully retract
If you don't have success, please let me know more details of what the tool is doing and I will try to talk you through it.
Jul 16, 2014 | Dewalt D51256K 16 gauge finish nailer kit
Cant fire tool on first job?
oil your tool everyday , also you may need to replace all orings
Jul 14, 2012 | Campbell Hausfeld 2-in 18 Gauge Brad...
My nailer won't work
Do you have a constant air leak at the head of the gun? If so you have a blown diaphram seal. Order from mfg.
Feb 10, 2012 | Shop Fox W1776 18 Gauge 38"2" Brad Nailer...
When should I oil it
if it requires oil the time to do so is first before use 6-8 drops of air tool oil and if using alot when you break for lunch another 6-8 drops. If it is not going to be used for an extended period of time about once a month and cycle the driver at that time.
May 16, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Do I need to oil this gun before use?
Yes, all air tools should have a few drops of tool oil dropped in the brass connector each day before use. Hope this helps.
Mar 09, 2011 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
I have difficulty with regular jams regardless of brad length. Thoughts?
Depending on type of work/wood the finer the nail, results in increased jams. Eighteen gauge and finer experience more jams than say 15 gauge. Fine gauge nails also suffer from square cut tip. I believe that if the nails were pointed (like Senco nails ) they would more likely drive true. Jaming can be decreased by selecting the correct nailer for particular work. Dimentional lumber and hardwoods tend to increase problems compared to quality plywood or non wood trim materials. If you experience jaming with any type of wood then time to look at driver for possible problem. Check driver for bent or worn tip. Driver blade can be dressed square on grinder. Some drivers have a slight angle/taper ground into tip on the side that faces the rails. This taper continues up the blade about 1/2 inch. The taper will prevent the driver from hitting the second nail. On really hard woods, try drilling a fine pilot hole to produce best results. Good luck
Mar 09, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Can not drive nails. Loud air hiss at top on tool
you have an air leak and you have to fix your stapler nailer hope its not cracked but just a seal
Sep 24, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
BN200A porter cable brad nailer. have tried
check for a broken driver blade, also make sure of the proper nail guage for the tool. Let me know if this is not the case and I will find you a breakdown for the tool for further inspection.
Nov 06, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Air Tools & Compressors Logo
27 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
