Question about Refrigerators
I HAVE A FRIGIDAIRE FRS26HF7BW1. NO WATER GOING TO ICE MAKER. UNIT APP. 6 YRS OLD. FIRST PROBLEM I HAVE HAD. WHAT'S WRONG. WATER TO DOOR IS FINE.
  • 4,059 Answers
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips
Posted on Sep 27, 2009
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
I have a side by side fridgeits about 10 yrs old
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
Aug 26, 2009 | Refrigerators
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Water comes out dispenser when ice maker calls for water
if the ice makers calling and its comming out of the doorthe valves are wired yhe wrong way around swop the wires from one valve to another. hope this helps
Feb 12, 2008 | Refrigerators
No water in ice maker or drinking water thru door
is this a fridge/freezer or a washing machine? ;-) (check title)
if it's a wm, and the motor runs, then probably a broken/lose drive belt, or clutch slip. Possibly brake not releasing, faulty switch or relay. Really need more precise description of symptoms before can give more precise help.
Jan 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped working on Frigidaire Model FRS262NHW3...
I would check the valve that provides water to the ice maker before doing any thing with the ice maker head. Check voltage to the valve when the ice maker is in harvest mode. (with a good volt meter). watch the meter for the whole harvest cycle or you will miss the reading. if volage is good 99% chance youve got a bad valve, assuming the inlet tube is not frozen. Best of Luck.
Sep 25, 2007 | Frigidaire FRT18FS5A
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
