When i take a picture with the kodak easyshare m853 it turns pink and lines are thru all of my pictures.i dont know why it does this but when i take pictures it shows up like that.i need help with this.please help me
SOURCE: m853 pink lines pink pictures
you may just have to take the cost of repairing or replacing it. for ashleyyy x0 and angela1178 if your screen only shows in pink no matter if your looking to take a picture or video or look through the menu the damage may be to the screen. for ginawell it seems there is damage to the data streaming from the lens to the lcd screen.
SOURCE: lines on pictures
Your CCD unit in your camera needs to be replaced. Contact Kodak.com to see if camera is still covered under warranty.
SOURCE: can not charge my kodak i think its my usb cable.
If trying to charge using USB through a computer, you have to have the computer on, booted up, and running! The only other thing to try if that is not the problem is to replace the USB line you use, checking plug ends for damage. Good Luck!
SOURCE: pictures are pink with lines
The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card.
Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
SOURCE: my kodak easyshare M753 has pink tint and lines
its obvious a malfunction that didn't occur by bad handling ..and if the device it is still in the warranty period , my advice is to go for it if you never open it or other things that you wouldn't suppose to do
