Question about Eiki LC NB2UW Multimedia Projector
When the power button is pressed the fan turns on and it sounds like it's all going fine. Then the Ready light (green) turns off and the fan runs for about a minute then the fan turns off and the ready light turns on again as if i never turned it on. i can do this over and over and i get no new results. i tried unplugging it for 3 hours and attempting again. Note: (no light ever comes out of the projector so i can't access menu or anything. I never saw the "Lamp replace light come on either.) What can i do? is it dusty? is the lamp needing replacement? is there a combination of buttons that can fix this?
  • 2,237 Answers
Power supply issue. the caps probably dried up. you'll need to replace the power supply. it is a good idea to blow the dust out of it with canned air.
Posted on Nov 17, 2009
  • 4 Answers
I suspect it isn't a power issue, but possibly a board issue. I have a lc-xnb2uwm that gives the similar behavior: plug it in and the lamp LED glows red. Green ready light comes on a bit later. Push the power button and the fan kicks in, but shuts down after a minute. Nothing out of the lens/bulb. Menu doesn't display.
Unplugged it and opened it up. I found a circuit board in the back left (over the AV ports) had a handful of ICs that looked partially melted. No other noticeable issues in the chassis at all. Without a schematic, it's hard to walk all the boards and they are really crammed in there, but I think it's a logic issue (unless the resolution coming out of your computer and to the projector is wrong). You can write http://www.eiki.com/ and see if they have any ideas, too. I'm looking for a spare model of mine for parts to try some board swapping. If it was a power issue, I suspect the thing wouldn't come on at all.
Posted on Jul 28, 2010
The ready light is flashing green then amber. What does this mean
This lights pattern means the waste tank needs the blotter replaced.
Then once replaced, the tank reset needs to be performed.
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and release the Resume button
4. Press Resume button 2 times then release BOTH buttons.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 15, 2010 | Canon i950 InkJet Photo Printer
I press the power button on the front and no fans run
Sounds like your power supply is not supplying 12v to the system. Check all your power connectors are seated properly on your motherboard, if so then i'm afraid you need a new power supply.
Mar 26, 2010 | Gateway 500GR PC Desktop
It will not power on when I press the power button and there is a blinking "A" light going off. When I press the power button the "A" light with a lock around it blinks, the fan sounds like it is going to...
try to run diags, press and hold fn key then press the power button an release them both at the same time when the computer turns on, check for any error message, or try to reseat your memory modules too
Oct 04, 2009 | Dell Latitude E6500 Laptop
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Its not the lc-sb20 but the lc-nb3e
Hi there
This sounds like a common Ballast ( lamp's power supply ) problem.
Only way to rectify this is by replacing the faulty Ballast.
Sep 08, 2007 | Eiki LC-SB20 Projector Multimedia...
Problematic Camera
I just discovered that the real problem is a STICKY SHUTTER BUTTON, staying down after taking a picture. This prevents the green ready light from coming on until I jiggle the shutter button. It has actually started to be hard to press, making a definite clicking sound as it goes down. I can even feel it catch on something. If I move it around a bit, it will eventually come up, allowing the ready light to reset. Can this be cleaned? How about adding a drop of WD40 or something? Anybody ever take one of these apart? Any tips as to how to do it safely??? Thanks.
Sep 13, 2005 | Kodak EasyShare DX4530 Digital Camera
Eiki LC NB2UW Multimedia Projector Logo
257 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
