Question about Yamaha Electrical Supplies
Yamaha gen 3000iseb throttle surging @ start up,not putting out any power ?
  • Yamaha Master
  • 5,603 Answers
Surging is not uncommon till warm and stable,
No power? Read this site:
http://www.endtimesreport.com/dead_gen.html
Posted on Nov 02, 2009
Hi I have a 3000iseb yamaha generator with no output after testing all wiring an recitifer all good think the problem is the control unit
Allmost all generators have little circuit breakers that when tripped will shut down the power output...
Jan 16, 2018 | Yamaha Motorcycles
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
Oct 17, 2016 | Electrical Supplies
I cleaned the injectors on 2006 yamaha vstar 650 got a little more power but when I open full throttle and release it some it is surging what could be making it surge now?
Hi, Peggy try running a can of fuel stabilizer (Sea Foam) in the gas tank otherwise the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
http://forums.cycleworld.com/showthread.php?t=128611
Star 950 Surging Yamaha Star Forum
Losing power on Vstar 650
http://s.productreview.com.au/products/manuals/32141_563ae9ef16ab5.pdf
Apr 10, 2016 | Yamaha Motorcycles
Model ef6600de. How do I decrease rpm?
Search Results
    [PDF]EF4000DE, EF5200DE, EF6600DE, YG4000D ... - Yamaha
    www.yamahamotorsports.com/assets/.../0/LIT-19626-01-15_1425.pdf
    Generator. LIT-19626-01-15. 7WV-28199-11. EF4000DE. EF5200DE. EF6600DE ...This manual will provide you with a good basic understanding of the operation and .....card listing your Yamaha model name, engine ... rpm. NO OTHER ADJUSTMENTS NEEDED. ENGINE OIL: IDLE SPEED: ..... Electric Starting Model:.
    [PDF]yamaha generator theory & diagnostics guide - Gen-Tech
    www.gen-tech.net/fullpanel/uploads/files/theory--diagnostics-guide.pdf
    Yamaha Generator Theory and Diagnostics Guide .... Conventional EF6600DE . ...models with Smart Throttle) do not rely on rpm to ... unit manages functions such as AC power modifica- ... tions means higher fuel economy at lower outputs.
    Yamaha Motor Canada :: Products :: Power Equipment ...
Dec 25, 2015 | Yamaha Electrical Supplies
Ef 2400 Is Yamaha generator Over Revs
Take it to a dealer, there is a solid state module inside that controls the charging and idle, also a wiring diagrams are available with owners manual, go to Yamaha web site also..
Apr 12, 2017 | Yamaha EF2400iS Portable Generator
Have a Honda EU6500is generator with 410 hours. I live off grid and run the gen 2-3 hours daily. The generator rpm surges under load on eco throttle and surges under load AND without load when the eco is...
i have the same problem with a new one ,take a peace of paper and cover the battery cover air inlet when it's running ,if your problem stops-it's the seal around the cover,a honda rep let the cat out of the bag,---jk
Sep 08, 2011 | Honda Electrical Supplies
1993 Yamaha XJ600 (pre divi) Mikuni carbs surging
Hi, Bevstait and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
New Seca II surging bogging under mid RPM load NOT CARBS XJRider com
surge at steady throttle
Yamaha FJ Owners Workshop Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Oct 03, 2010 | 1993 Yamaha XJ 600 Diversion S
When I run my generator - a Yamaha EF2400S to my Zantrex Model MS2000, it will not accept the power to charge my batteries. The generator's voltage and frequency, when checked, are within acceptable...
the power coming from your generator is probably "dirty", full of spikes and surges from the generator. If it accepts shore power and not gen power, then the generator is the most likely cause. If the generator in unregulated, you are stuck, but it could have a failing voltage regulator board, or Yamaha may have a solution.
Jan 09, 2010 | Xantrex Technology Heart Freedom 25...
3000iseb will start but will not rev up. sits and
check air filter and exhaust for blockages. Sounds like it is choking
Sep 20, 2009 | Electrical Supplies
Electrical Supplies Logo
279 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
