Question about Casio Exilim Zoom EX-Z700 Digital Camera
White Result When I take a picture, result is subject taken is white in color, it's like over expose, I turn off flash, still same result. Please help
  • 3 Answers
Its over exposure. lens error..
Posted on Jan 21, 2008
When taking a picture in daylight and the background is bright the background comes out as white-no colour. I've tried fill in flash and also exposure compensation to no avail. Very frustrating-please...
Your camera is setting its exposure to your subject, which if it's darker than the background will cause the background to over expose. You need to set the exposure to the background which then will cause your background to be properly exposed and your foreground or subject to be darker. With a point n shoot camera, accomplishing this might be a difficult task. But if you expose to the background and use the fill flash, you should then get your properly exposed image.
Jun 04, 2014 | Nikon COOLPIX S5100 Digital Camera
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Bought this product on 28/03-08 at bangalore.all snaps taken out-doors becomes too whitish and not able to see anything, the lcd screen on review shows no snap..but white over exposed result even at...
make sure your ISO setting is set to Auto. Even in auto mode its possible to set your ISO manually. If the ISO is set to auto and the pictures are still to bright, your sensor may be bad. Also make sure your exposure compensation is set to 0.
Mar 20, 2009 | Kodak EasyShare C613 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Picture display result
Which mode are you shooting in?
You may have adjusted the exposure compensation so everything is washed out.
Whatever the cause, your images are overexposed. Try shooting in auto and the camera should take over the settings, but if you are in other modes, check your shutter speed, aperture, & ISO also. These are all things that can cause too much light and wash the picture out/OVEREXPOSE.
If you have any other questions or can give me more details, just ask!
Hope this helps!
Jun 01, 2008 | Canon PowerShot A460 Digital Camera
White vertical light !!!
Vertical light in the frame was the equalize the brightness of the frame to shoot 2 , 3 sometime 1 time for shooting object /don't shoot 2 or three frame very dark result.
Jan 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
"Black board" and "White board"
A monochromatic subject is taken in B/W colors. When "White board" is selected, letters written on the white board are clearly read on the taken picture. The same is for "Black board". If letters are not clearly taken selecting "White board" or "Black board", use the exposure compensation.
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
48 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
